Discussing Sub Frame Connectors in the 5.0 Mustangs Forum. Originally Posted by ryans88gt That's kinda backwards. You should support the car and level ...
Old November 19th, 2007, 01:37 AM   #21
78mach1's Avatar
Originally Posted by ryans88gt View Post
That's kinda backwards. You should support the car and level it by the frame. Most foxbodys sag in the middle when they are just sitting on the wheels. So actually the frame is tweeked when it is sitting on the wheels. Most cage builders start by leveling the car by the front and rear subframe. That is how the car is supposed to be. The you weld in your supports to keep it straight and level like it is. But, you have to take great care in making sure you have leveled the frame so it is straight before you start. Otherwise it will never be straight again. You should not lift it by the pinch welds that will throw everything off too.
ok so in a way we are bolth right
but i understand what your saying about leveling it by the frame
but using a "A SEMETRICAL" lift, its kinda hard to level it and get it perfect cause those lifts arent always perfect.
so maybe jack stands are a good idea in a way, if there all perfect and your level in your garage
In Memory of Nick Goris.
Threads Similar to: Sub Frame Connectors
Sub Frame Connectors? 07 procharger 2005+ 17 November 16th, 2007 01:26 PM
Sub Frame connectors DrHolliday 99-04 21 April 5th, 2007 12:58 PM
Sub-frame connectors 2000Mustang The Clubhouse 2 April 4th, 2007 10:59 AM
Sub-Frame Connectors cristo Suspension 7 March 20th, 2007 05:12 PM
How Long Are Sub Frame Connectors? jims92mustanglx Suspension 5 February 23rd, 2007 09:43 PM
