Discussing Sub Frame Connectors in the 5.0 Mustangs Forum. can i just weld 2 sturdy bars of steel like square tubing or should i ...
Old November 16th, 2007, 09:49 PM   #1
e3sean's Avatar
can i just weld 2 sturdy bars of steel like square tubing or should i stop being cheap and buy some??
Old November 16th, 2007, 09:51 PM   #2
I Touch Myself Sometimes
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
buy some.
MILITARY CREW
FOUNDER
Originally Posted by DeMello View Post
looks like i demellowed myself
sry OP
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebands
email joe@tricktuners.com
Old November 16th, 2007, 09:57 PM   #3
Speedstang302's Avatar
1989 Mustang LX 5.0
12.86@ 111mph
1989 Mustang LX 5.0
Stock w/ F303 cam and 1.6 Roller Rockers
BBK Shortys, BBK o/r H, Flowmaster Super 44s
"The LS1 was subject to a paternity test!!! The results are back....03 cobra you are the Father!!!!"
Old November 16th, 2007, 09:59 PM   #4
1987 ford mustang gt
well see when shes done
comp engineering bolt ons and then weld em
347 stroker little street car yea its slow!!
Old November 16th, 2007, 09:59 PM   #5
e3sean's Avatar
thanks nuff said
Old November 16th, 2007, 10:02 PM   #6
1989 Mustang LX 5.0
12.86@ 111mph
got that link j...i wanna get some real soon
1989 Mustang LX 5.0
Old November 16th, 2007, 10:18 PM   #7
Competition Engineering Bolt-On Frame Connectors: CEE-3141 - summitracing.com
i got em on my car and they fit great
Old November 16th, 2007, 10:50 PM   #8
nolife's Avatar
If you have access to a welder, some stock, and some time to kill, build them yourself. I would not consider that being a cheap skate. The ones you buy are nothing but stock cut to length with brackets welded on that you will either bolt or weld to the car anyway.
1991 GT - Original owner, all stock
1988 GT - The project car
Old November 16th, 2007, 11:06 PM   #9
1989 Mustang LX 5.0
12.86@ 111mph
i know you do..why you asking like i dont even know you...and thanks
1989 Mustang LX 5.0
Old November 16th, 2007, 11:14 PM   #10
I know that you know but the noob didnt
Old November 16th, 2007, 11:22 PM   #11
8t6gt's Avatar
1986 Mustang GT
I will back Jordan on the Comp engineering I have those on mine they work very well and fit like a glove
Hurst Crew member #2 of 21
Co Founder of all crews.
Lee B and 8t6 the founders of crews
Originally Posted by Squints View Post
i'm all for global warming. who needs polar bears anyway?
Old November 16th, 2007, 11:29 PM   #12
Rustbelt's Avatar
i need to get some in the spring. $122 is not that bad. did u use jack stands or a lift to get them on? cause i dont have access to a lift anymore.
Old November 16th, 2007, 11:32 PM   #13
8t6gt's Avatar
1986 Mustang GT
Lift. I four use jack stands make sure you put four in the same spots all the way around the car.
Old November 17th, 2007, 12:08 AM   #14
Devine's Avatar
1992 LX 5.0
maximum motorsports installation instructions say to make sure you keep the weight on the springs. it's most important to keep left and right even, so you don't flex the frames.
Best option - drive on lift
second best - ramps
last option - use jackstands under the suspension to keep the weight on the springs.
Old November 17th, 2007, 12:11 AM   #15
8t6gt's Avatar
1986 Mustang GT
A normal lift works just fine if you lift it up righ thats what I used and I didnt have any problems
Old November 17th, 2007, 09:57 AM   #16
Devine's Avatar
1992 LX 5.0
yeah, i guess that would work the same as jackstands if you could get them in the right position
Old November 17th, 2007, 10:34 AM   #17
I PUT MINE ON WHILE THE CAR WAS on jackstands
Old November 18th, 2007, 08:22 PM   #18
its safer to just go ahead and buy some it will make the bottom of the car look alot cleaner then just some scrap metal
Old November 19th, 2007, 12:07 AM   #19
78mach1's Avatar
well that can or cause some problems
when you lift the car it flexes, you bolt them on, and when you lower it, it doesnt unflex so your car is kinda tweeked all the time so it throws off your alighment
so its best to use a drive on four post lift so all the weight is still on the wheels so your car is just sitting normal, but your have the room and can stand up, so it makes it easier to put on
im not saying there is anything wrong with your car but that has happend a few times
78 mustang II, mild 306
88 GT
Originally Posted by Darrell View Post
Yeah but the only thing most "old camaro owners" are sporting is a mullet and rotten teeth.
Old November 19th, 2007, 12:27 AM   #20
ryans88gt's Avatar
That's kinda backwards. You should support the car and level it by the frame. Most foxbodys sag in the middle when they are just sitting on the wheels. So actually the frame is tweeked when it is sitting on the wheels. Most cage builders start by leveling the car by the front and rear subframe. That is how the car is supposed to be. The you weld in your supports to keep it straight and level like it is. But, you have to take great care in making sure you have leveled the frame so it is straight before you start. Otherwise it will never be straight again. You should not lift it by the pinch welds that will throw everything off too.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph
88 GT 11.4 @ 118
Threads Similar to: Sub Frame Connectors
Sub Frame Connectors? 07 procharger 2005+ 17 November 16th, 2007 12:26 PM
Sub Frame connectors DrHolliday 99-04 21 April 5th, 2007 11:58 AM
Sub-frame connectors 2000Mustang The Clubhouse 2 April 4th, 2007 09:59 AM
Sub-Frame Connectors cristo Suspension 7 March 20th, 2007 04:12 PM
How Long Are Sub Frame Connectors? jims92mustanglx Suspension 5 February 23rd, 2007 08:43 PM
