Fuel Pump problems
I have an 89 GT. I was driving the car and it suddenly just died and would not restart. The fuel pump is not running. I recently purchased the car and the car had not been driven in some time. My gut instinct was that the pump had gone bad. I replaced the pump and had the same issue. Next step, it has to be the fuel pump relay, so I replaced it. Any ideas on where to start next. I am getting a code 95 from the system. Can anyone help short cut the issue for me?
Did you have 12V at the pump
Did you have 12V at the pump, You did replace the fuel filter, correct?
Have you checked the inertia relay? It should be in the trunk on the drivers side, be sure it is good. should have less than 5 ohms resistance across the terminals. Do you have 12V there?
"Those who forget the past are condemned to repeat it" Rev. Jim Jones |
Do you own a multimeter? Did you check for power before replacing the Pump? Should have.
I initially did not check voltage. I was really confident that the pump had just gone out. I did however check for voltage tonight. I have nothing at the pump, I have nothing on either side of the inertia switch. I then went to check for current at the relay. No so good. I looked up the schematic for the wires to test out on the fuel pump relay, put the multimeter to it, and as soon as I touched my ground, I get an arc. Now I know I must have a short somewhere. Any ideas? Anyone? I'm now leaning toward a faulty ignition switch.
95 (O) Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
(R) AIR not Diverting (AIRD) - Air Injection (M) Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) - Power / Fuel Pump Circuits
89's have the relay under the seat still, so should be easy to run some power direct to that thing and call it a day.
Threads Similar to: Fuel Pump problems
| 1998 Chevy Fuel Pump Problems | mattstang | All Other Vehicles | 5 | December 18th, 2007 12:10 AM |
| Gas pump problems | AnimalCrackers | 2005 - 2010 | 9 | July 13th, 2007 10:37 PM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 04:31 PM |
| HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? | 1slowhatch | 5.0 Mustangs | 0 | April 21st, 2007 07:48 PM |
| Fuel Pump Problems | bigbadtalontsi | 5.0 Mustangs | 5 | March 30th, 2007 05:50 PM |
