ATF Fluid in T5 Transmission? From Tech Article
LinkBack (4) Thread Tools
Old August 24th, 2006, 06:43 AM   4 links from elsewhere to this Post. Click to view. #1
83 5.0's Avatar
83 5.0 is on a distinguished road
Just read the Tech article ont he T5 swap and the writer mentions putting ATF fluid in the T5? Will Automatic Transmission fluid harm the bearings etc. I assumed gear oil would be used? I will be putting my T5 in shortly and want to use the best fluid. Thanks
Old August 24th, 2006, 03:02 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
All T5s use ATF. There aren't many transmissions that use gear lube anymore. Some Chrysler manual transmissions use 5w30 motor oil.
Old August 24th, 2006, 03:11 PM   #3
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
Mmmmmmm........did not know that and I have a T-5 in my 66. I will make a note of that, thanks.
Classic Mustangs are the best! Get one.
Old August 24th, 2006, 07:59 PM   #4
83 5.0's Avatar
Thanks!! Man I learn more every day from this group, Thanks again!!!
Is it just the standard Ford ATF fluid, (Mercon or sounds something like this?)
Old August 25th, 2006, 12:43 AM   #5
IcantDo55 is on a distinguished road
No synthetic ATF! use the cheep stuff!
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old August 27th, 2006, 01:15 PM   #6
stanginfection is on a distinguished road
A lot of guys seem to think ATF won't properly lube their gears and bearings in a manual tranny. There are gears and bearins in Autos also!
I made the mistake of putting Full Syn oil in a Tremec 4sp manul W/Brass syncros. After a couple of thousand miles it would no longer shift without using a lot of force. The Syn wouln't let the brass grab the steel gear. I took the tranny apart and absolutly nothing wrong, just wrong oil.
The old steel case Top Loaders use gear oil.
Old August 27th, 2006, 11:51 PM   #7
T-5's run ATF! Thats what should be in there.
-Mike
Link to My Site
Stroked and Blown!
Old August 28th, 2006, 11:20 AM   #8
I agree. I was trying to explain why synthetic oil could be a bad Idea.
Horseshoeing has a 66. It came with a toploader unless a T-5 was swaped in.
Old August 28th, 2006, 05:54 PM   #9
I put synthetic in my t-5 and it would not shift and had to drain it and replace it with some cheep pepboys atf and than it shifted. Just trying to save you people some headaches.
-Mike
Link to My Site
Stroked and Blown!
Old August 29th, 2006, 01:07 AM   #10
SELLC's Avatar
SELLC is on a distinguished road
BLAH-BLAH-BLAH
SOME KNUCKLE HEAD DELETED MY POST IN THE CLUB HOUSE! What a load of shhheeeeaaaatt.
ATF was used only to create less drag. The old models used the thicker 90W lube because it was better in terms of vicosity break down, and no one gave a rat's ass about economy.
Anyway my thread in off topic was about this fricking BS website for Mercedes. It was a good thread and you were all robbed of a good time!
Here is what a camaro owner said about the Anti-American Mercedes site-
"nice car. and im sure that the mecedes owners are far too intelligent for us Americans... haha (Sarcasm)" AuSStin - Camaroforums.com
I thought it was funny.
Old August 29th, 2006, 02:19 AM   #11
SELLC
and that has to do with ?????
Old August 29th, 2006, 02:42 AM   #12
SELLC's Avatar
SELLC
That has to do with why the T5's got ATF instead of 90w.
Duh... Are we a little slow tonight? You been hanging out in the treehouse in the drunk thread a little too long bud-bud?
Old August 29th, 2006, 11:26 AM   #13
SELLC
Hello Newbe, in our little corner of the internet we like to keep things on topic and if we (mods) don't see that things stay on topic they tend to get....gone. Sorry for any inconvience.
Back to your T-5 topic....
-Mike
Link to My Site
Stroked and Blown!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/4312-atf-fluid-t5-transmission-tech-article.html
Info.com - t5 transmission fluid - www.Info.com This thread Refback November 18th, 2011 08:41 PM
Rex Umney - Forum Scammer This thread Refback April 6th, 2011 10:12 PM
Rex Umney - Page 2 - Forum Scammer This thread Refback February 9th, 2011 02:01 PM
Info.com - t5 transmission fluid - www.Info.com This thread Refback December 23rd, 2010 05:42 AM
Threads Similar to: ATF Fluid in T5 Transmission? From Tech Article
5.0 Tech Article Directory mdvaldosta 5.0 Mustangs 27 February 20th, 2011 11:40 PM
What Transmission Fluid? Murderjetz General Tech 8 November 11th, 2007 12:39 AM
TRANSMISSION FLUID ROUSHME661 V6 Mustangs 17 July 14th, 2007 03:04 PM
transmission fluid firefly1241 5.0 Mustangs 10 April 1st, 2007 05:33 PM
transmission fluid 1990CA50 5.0 Mustangs 1 December 12th, 2006 02:48 PM
