Ignition
Old November 19th, 2007, 03:51 PM   #1
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
Ignition
anyone on here running the summit equivalent to the msd 6al box. the msd is like $250, and the summit i beleive is $180
85 svo. work in progress
Old November 19th, 2007, 09:01 PM   #2
baine21225's Avatar
i would spend the money on the msd, i have personally never heard anything about the summit and im not saying that its bad. i just think the support and the name of msd is in a little better stature
Old November 20th, 2007, 12:16 AM   #3
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
I agree you can't go wrong with msd, I would spend the extra money
Old November 20th, 2007, 07:06 PM   #4
notchabovechevy is on a distinguished road
okay I don't have one but I do have info
summit is didgital msd analog primary output(s)520v (msd)470v spark energy(s)135mj (msd)110mj min. max operating voltage (s) 8v/16v (msd) 10v/18v current draw (s)0.6 per 1000 rpm's (msd) 1 amp per 1000 rpm's rev limiter(s) 12,000 rpm's dail 250 increments (msd) 8,000 rpm's moduals/pills 4 pills 1,000 rpm inc. price (s) $160 (msd) $237 This add in summit mag. Has comparo of a few others if you are scared of the name get a mallory hyfire 6al exact same specs as summit racing $180 good luck
Old November 20th, 2007, 11:12 PM   #5
capriboy is on a distinguished road
I brought a summit box for 119$ to replace my aging duraspark, and it works very good. The hook up was simple soo far so good. Its really a mallory unit made for summit. The car runs soooo much better; it was money well spent ( so far)
83' capri 306ci hyper pistons, stock rods with ARP bolts, FMS E303 cam,TFS springs, RPM intake- 600cfm carb, Sorry E6s, bbk shortubes no cats , H pipe 2ch flows dumped, C4 trans, 3.73 gears, SSM uppers CE shocks 4cly springs, svo lowers,subs
Old November 22nd, 2007, 01:06 PM   #6
when i get the ignition box will i have any probs with using the stock distributor
Old November 23rd, 2007, 09:59 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Why do you want to upgrade the ignition on a stock or very mild car? Why don't you just send me a check for $180?
Threads Similar to: Ignition
ignition theodoor24 Classic Mustangs 4 March 30th, 2007 10:37 PM
MSD IGNITION mightyb28 99-04 5 March 16th, 2007 07:12 PM
MSD IGNITION mightyb28 General Tech 2 March 13th, 2007 08:27 PM
Ignition maverick 2005 - 2010 30 January 12th, 2007 07:11 PM
msd ignition on 98 gt burlingtonNC98GT 96-98 5 January 3rd, 2007 12:28 AM
