How Do I Install A 5" Autometer Tach #233904?
Old November 19th, 2007, 06:02 PM   #1
good_fellaz_76 is on a distinguished road
Send a message via AIM to good_fellaz_76 Send a message via Yahoo to good_fellaz_76
can anyone tell me how to install a 5" Autometer Tachometer #233904! I would like to do it myself but was wondering if anyone can give me step by step instructions! i would really appreciate it! Thanks
Old November 19th, 2007, 06:06 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
which tach?
Old November 19th, 2007, 06:06 PM   #3
TurboLX's Avatar
the series name?
Old November 19th, 2007, 06:09 PM   #4
1988 Mustang Notch
it's a bad bitch..i promise
CAMN89GT is infamous around these parts
Hold on....
'88 Notch ~ T-70 & Faceplated GForce!
Tuned by [B][I][U]Kurgan Motorsports[/U][/I][/B]
Old November 19th, 2007, 06:13 PM   #5
1988 Mustang Notch
the white wire goes to the 12v dash lighting
the red wire goes to the 12v ignition switch
the black wire needs to be grounded
the green wire goes to the negative on the coil.
Old November 19th, 2007, 06:17 PM   #6
1988 Mustang Notch
you know, if people really used google.com , it'd help....
how ever,
Auto Meter
go there, find ur own tach , and get the instructions downloaded. if you dont have adobe 3.0 +, u wont be able to open the file. if thats the case, go to adobe.com and download it, its free. enjoy
Old November 19th, 2007, 06:18 PM   #7
TurboLX's Avatar
this is how i did mine
i put the 12v dash light into an open spot in the fuse box
the ignition wire was wired into a hole under the ignition cylinder
black wire i grounded somewhere
and ran the coil wire thru the firewall into the coil
its an easy install
Old November 19th, 2007, 06:18 PM   #8
1988 Mustang Notch
its an easy install
^^ durrrrrrrrrrrrrrrrrrrrrrrr
Old November 19th, 2007, 06:20 PM   #9
TurboLX's Avatar
im just telling it so he can make it easier for himself
Old November 19th, 2007, 06:23 PM   #10
1988 Mustang Notch
i know that and Im bored.
Old November 19th, 2007, 11:31 PM   #11
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
how ever,
Auto Meter
he practically said it all......just get under there with a test light and start touching wires.......youll be fine!
haha jk but ya use the fuse box...it should have prongs that you can put a end on the wire and plug it into (for the lights, and the twelve volt ignition wire that turns on with the key)
Old November 20th, 2007, 09:53 AM   #12
Speedstang302's Avatar
13.64@101mph
he hasnt even come back yet and you're already fighting over who said it correcter...idiots..
turbo im pretty sure most autometer models wire up same exact way..i did mine this way \/
s
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old November 20th, 2007, 11:26 PM   #13
couldn't i just connect the red with the red at the coil and the green with the green at the coil and the black to the battery?
Old November 20th, 2007, 11:27 PM   #14
also what if your gauge reads past the 10 is that normal?
Old November 21st, 2007, 03:37 PM   #15
78mach1's Avatar
no the red is for something else.....but the green goes on the negative part of the coil....that tells your tach what rpm`s your at
Old November 21st, 2007, 08:40 PM   #16
so the red on the coil isn't the ignition?
Old November 21st, 2007, 11:28 PM   #17
1988 Mustang Notch
also, if this tach was not new, the previous owner could of cut the 2 wires in the back(small small wires) either for a 4cyl or a 6cyl, 8cyl(this one are where none are cut) i think the brown = 6cyl, and white = 4cyl. (I am possibly wrong, I didnt check on autometer, and I dont quite remember) That could be fucking up ur rpm aside from ur stock tach.
Old December 4th, 2007, 03:20 AM   #18
White Knight's Avatar
White Knight is on a distinguished road
Stupid question: What and where is the coil? What does it look like? I know it's under the hood but that's all I know. Anyone have a pic?
1989 Mustang LX 5.0 5-speed
Underdrive pulleys, cold air intake, shortthrow shifter, flex fan, Flowmasters, whiteface gauges, Autometer Gauge Pod with Phantom tach, oil, and water gauges, Cobra tail lights, arm rest with cup holder
Old December 4th, 2007, 03:35 PM   #19
13.64@101mph
its on the drivers side..it has an spark plug connected to it..its on the side of the drivers side shock tower...right near the starter solenoid..usually black
Old December 4th, 2007, 03:40 PM   #20
TurboLX's Avatar
turbo im pretty sure most autometer models wire up same exact way..i did mine this way /
[/i]
s
i was saying how i wired mine
Threads Similar to: How Do I Install A 5" Autometer Tach #233904?
tach driver install Blk01ponyGT 99-04 4 November 17th, 2007 06:10 PM
anyone ever install a tach on a 99-04 v6? PLEASE HELP! ricerraper33 Audio/Video 8 September 20th, 2007 09:35 PM
Tach install Quick question please!! Troyzstang Modular Mustangs 8 November 17th, 2006 05:40 AM
sun pro tach install terribleonexx88 5.0 Mustangs 1 October 19th, 2006 01:18 PM
autometer tachometer cali 5.0 5.0 Mustangs 1 August 20th, 2006 09:00 AM
