Car shaking below 1500 rpm
Old August 24th, 2006, 06:14 PM   #1
90Stang's Avatar
2005 Mustang
12.9@109
90Stang is on a distinguished road
Send a message via AIM to 90Stang Send a message via MSN to 90Stang
my car has a shake and sometimes it does it worse than other times and it will quit shaking if you rev the motor above 1500rpm or if you push in the clutch it will almost quit but still does it a little. i am wondering if the problem is in the tranny or what.
Old August 24th, 2006, 06:20 PM   #2
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
Does it do it when you are stopped and reving the motor? Could it be the trans mount?
Classic Mustangs are the best! Get one.
Old August 24th, 2006, 06:22 PM   #3
90Stang's Avatar
2005 Mustang
12.9@109
it does it when i am stopped at an idle or in neutral at an idle coasting, but as soon as you rev the motor it quits shaking.
Old August 24th, 2006, 11:44 PM   #4
IcantDo55 is on a distinguished road
Check the harmonic balancer. Look close, if there is any rubber sticking out, its bad. common after 15 years.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old August 25th, 2006, 06:18 AM   #5
ttop5.0's Avatar
ttop5.0 is on a distinguished road
i had a similar problem, maybe not the same as you but check your plug wires and plugs something may not be firing right, i mixed up plug wires once and got similar resultss to what you are saying, it's worth a shot....check your firing order..
Old August 25th, 2006, 01:40 PM   #6
Anthony is on a distinguished road
+1
Threads Similar to: Car shaking below 1500 rpm
my car is shaking? villatic V6 Mustangs 44 June 22nd, 2007 09:09 PM
My whole car started shaking... Really bad vibrations ??? 1911A1 5.0 Mustangs 8 February 28th, 2007 09:13 AM
Shaking at the wheel Wilson00V6 V6 Mustangs 3 December 10th, 2006 08:47 AM
Grinding Or Shaking Sound Bill 5.0 Mustangs 20 November 3rd, 2006 11:59 AM
Shaking Problems garyvang 5.0 Mustangs 3 May 10th, 2006 07:04 PM
