1990 Mustang GT
Help (GT40 Heads - Won't Start)
I just put on some GT40P heads, with new springs, rollers and lifters. I went to start it up and it wont. i rechecked all the connectors and lines, but still nothing. i dont know what to do. is there anything that i am missing or can anyone think of anything that might help....also does anyone have the belt diagram available?
#2 | |
is the batt. charged?
#4 | |
wow that was like every possibility in one long run on sentence! if he used after market pedestal rockers and didnt shim them they might be keeping the valves open |
1990 Mustang GT
no i installed a set of roller rockers, they are pedastal mount, i had the springs installed to specs. yeah i have fuel, but it seems like it is flooding itself. have spark and compression, and havent been able to check the timing correctly yet. still no belt diagram?
#6 | |
It's been mentioned. But, how much compression do you have? If the valves are not adjusted (shimmed or ??) the compression would suffer, right? If it seems to be flooding then fuel must be building up in the cylinders. Maybe there isn't enough compression to get good combustion. Do you have at least 140 psi?
13.64@101mph
how you even going to geuss the problems..could be dead battery, could be bad starter selanoid, could be plug wires in wrong spot...as easy as those...
does it turn over or dead on start...does it backfire when trying to start?
what kind of roller rockers? did you put the distributer in correctly?
Well you could have the distributor 180 out. The belt only goes on one way, if it is on, then it is on correctly. Double check your firing order with the plug wires.
Any more information about what the engine is doing would help. Like does it backfire, ping, pop, just no firing, is it cranking over fast, etc... Did you check the lash when you bolted down the rockers? Several people have mentioned this above and I am not sure if you understand. Should be about 1/4 to 1/2 turn past zero lash. If you had to tighten more than 1/4 to 1/2 turn you need shims under the pedestals or you will be hanging the valves open and it will never start.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1990 Mustang GT
Well lets start with what its doing exactly. I went to start it up, battery fine, turned over about 5 times but didn’t start. checked all wiring, fuses, lines everything was fine. tried again nothing. I have checked the distributor but with the ignition module attached can it be 180 out? I put it in the same position it was in when I took it out. I tried to check compression today but I believe I was unsuccessful at it, or I have absolutely none at all. yeah I figured that was the deal with the belt, but was double checking. I checked the firing order and spark several times. I guess what it does sound like is low compression. this was my first install on a set of roller rockers, which were I believe PROFORM 1.6 rollers. I read that I was suppose to torque the rockers to 18 ft-lbs so that’s what I did. should I take off the covers, loosen them until they are just tight the tighten them a quarter turn or something? or is it suppose to be 18 ft-lbs but just add shims?
Yes the distributor can be 180 out. Was the rotor facing the same direction as it was when you pulled the distributor or is just the distributor itself facing the same direction?
#13 | |
Good luck!
did you mark the distributor twice when removing it?you should have marked where the rotor was installed and then when it spun when removed.then when you reinstalled just reversed the process.
RUN WHAT YA BRUNG,HOPEFULLY DONT TOW IT HOME 93 GT AOD(SLUSHBOX)HA HA 3.73,TSI TRANZ,306,BENNETT HEADS AND CAM,ALUM SHAFT...BLAH BLAH BLAH |
get the number 1 cylinder to TDC on the compression stroke and retime the dist. number 1 on the dist should be pointing directly @ 12 oclock towards the firewall. Make sure your rotor button points that way. then put the cap on, and have someone turn the engine over and slowly turn the dist one way or the other until it starts up, then finish off with a timing light.
if you think its getting to much fuel, and you have tired multiple times to crank it up. you might have started washing down the cylinder walls already. take the oil dipstick out and see if the oil smells like gas.
1986 Mustang GT t-top time piece! |
1990 Mustang GT
rgr that. i will hopefully get a chance to work on it a little this weekend. thanks for all the help. i will let you know how it turns out.
1990 Mustang GT
alright i played around with it this weekend, loosened all the rockers until just tight, but still no start. i'm contemplating taking it to the shop and have them look at it, but if anyone lives in augusta, ga i wouldnt mind a little help first?
Adjusting your rocker arms that way is not the proper way and is going to further complicate your problem.
#19 | |
See my post above about how to adjust your rockers. If you don't understand it, take the car to someone that knows what they are doing.
1990 Mustang GT
ah ok i see...i will hit this up again this weekend
Threads Similar to: Help (GT40 Heads - Won't Start)
| GT40 or 351w heads | B.A.M302 | 5.0 Mustangs | 4 | August 20th, 2010 09:41 PM |
| GT40 Heads | fastford3388 | 5.0 Mustangs | 6 | September 29th, 2008 10:44 PM |
| gt40 heads.... | fastford3388 | 5.0 Mustangs | 4 | March 9th, 2007 05:49 PM |
| gt40 heads? | acg | 5.0 Mustangs | 4 | January 25th, 2007 09:14 PM |
| gt40 p heads | 03stanger | 5.0 Mustangs | 5 | January 6th, 2007 12:14 AM |
