Motor Mods
Old November 19th, 2007, 11:30 PM   #1
5.0 Junky is on a distinguished road
Motor Mods
What's the best Turbo Charger to purchase and what kind of HP increase can i expect to see?
I have a 1989 Mustang LX,with 24,000 original miles...The car has been garage kept,well maintained and is in excellent running condition...I have added some aftermarket parts(Chassis and motor) and i am looking for some more performance...
Here's my list of bolt-on items...
Motor....
Under-drive pulleys,K&N air filter(air box removed),70 MM throttle body,73MM Mass Air Flow Sensor,Cobra Intake Manifold,Cobra Roller rocker arms,Performance Distributor Ford distributor,MSD ignition box,MSD plug wires,ceramic coated shorty headers,Aluminum racing radiator,180* thermostat,new racing computer(Installed,programmed and dyno- run),H-pipe,converters removed,Flow Master exhaust and i run synthetic oils everywhere...
Chassis....
Steeda lowering springs,new struts,new bushings,sub-frame connectors,tower brace,12" front rotors,73MM clipers,rear disc-brake conversion,new 1 1/16" MC,steel braided lines,proportioning valve,off-set control arm bushings,Steeda X-5 ball joints,bump steer kit,aluminum off-set rack bushings,aluminum drive shaft,3:55 gears,Cobra R rims and Nitto extreme tires..
Without changing cylinder heads,or swapping camshafts,what's my best choice for more power?
Old November 19th, 2007, 11:32 PM   #2
baine21225's Avatar
asking what is the best turbo is like asking what is the best motor or what is the best color, it all depends what your preference is, how fast you want to go, and how much $$$$ you have
Old November 19th, 2007, 11:34 PM   #3
13.64@101mph
quicktime makes a really nice turbo kit...but baines right...depends on you're goals and current motor..
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old November 19th, 2007, 11:58 PM   #4
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
i have read that same sentence like nine times......i swear its like all these 16yr old kids just all the sudden want a turboed 5.0
Old November 20th, 2007, 12:01 AM   #5
13.64@101mph
^^^ yep
Old November 20th, 2007, 12:26 AM   #6
baine21225's Avatar
preaching to the choir my friend
Old November 20th, 2007, 01:04 AM   #7
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
ding ding ding we have a winner
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Threads Similar to: Motor Mods
need some help american motor to import motor wadepetersen V6 Mustangs 29 May 30th, 2007 10:26 AM
How do you find the motor code on a 88 5.0L motor? semihemi428 5.0 Mustangs 1 March 16th, 2007 05:56 PM
what mods should i do to my 02 gt Paulnhbtx 99-04 7 February 14th, 2007 12:45 AM
07 top 5 mods for under 400$ TDog 2005 - 2010 22 February 9th, 2007 11:39 PM
