1988 Mustang GT Vert
PCV Location?
Anyone any help on where the PCV valve is located? This could be the cause to all my problems
Big timin' in a small town
Its on the back of the intake
its on the lower intake in the center in the back
RUN WHAT YA BRUNG,HOPEFULLY DONT TOW IT HOME 93 GT AOD(SLUSHBOX)HA HA 3.73,TSI TRANZ,306,BENNETT HEADS AND CAM,ALUM SHAFT...BLAH BLAH BLAH |
is there any easy way to get to it? thanks for all the good and quick responses
I found it when I took the intake off so it was easy to get to then but see if you can just reach your arm back there and get at it
specifically what problems are you having?
Stumbling, Vibration, Stalling...
sounds like a vacuum leak to me
How would I check that to make sure of what it is? Thank you
Be a little more specific. Like does it stall at start up stoping at stop lights. Vibrations when at a certian RMP
Alright it backfires at start up, then it stalls even after its warm, and really bad vibration just started today at idle
hows your fuel pressure,are you sure the ignition wires arent "crossfiring", etc?
an easy way to check plug wires for crossfiring is have the car running in the drk and mist water over them with a windex bottle,i caught mine crossfiring right to the heads at the boots
yup replaced everything besides the PCV valve, so no, I thought that would fix my problem so I gave the car tune up, everything besides the PCV valve
did you do any mods before this happened, or just out of the blue?
Just out of the blue
no codes?
wweeeiiiirrrdddd
nope... Is it anyway it could be the PCV valve?
well its a cheap fix so its worth a try
Threads Similar to: PCV Location?
| PCB Valve Location? | dgt_mustang | V6 Mustangs | 5 | November 21st, 2007 11:02 PM |
| VA Location?? | 1994vert | Northeast | 5 | September 9th, 2007 04:02 PM |
| PCV valve location | speedstream | 99-04 | 9 | July 17th, 2007 05:01 PM |
| location??? | sb2f5marine69 | 5.0 Mustangs | 1 | April 14th, 2007 06:03 PM |
| Computer Location | bigbadtalontsi | 5.0 Mustangs | 3 | January 18th, 2007 01:36 PM |
