Do I Need 24lb Injectors?
Old November 22nd, 2007, 11:24 PM   #1
88dragstang is on a distinguished road
Heres the scoop. I have an 88 gt mustang drag car, gutted out. Engine: stock block, pistons and crank. 289 hi po heads (nice port and polish job). Trickflow Stage 1 camshaft. BBK cold air kit. STOCK UPPER AND LOWER INTAKE AND 58MM THROTTLE BODY! Anyway, I am planning on putting a different intake and throttle body on. I am looking towards a trickflow track heat intake and bbk 70 mm throttle body. Do I need to jump from the stock 19lb up to 24lb injectors? If so, will the stock fuel pump handle the 24lb injectors?
Thanks, Joe B.
Old November 22nd, 2007, 11:28 PM   #2
13.64@101mph
Thanks, Joe B.
those heads ported or not arent much better than the stock E7s...until you get that intake, which i'd do street heat considering you're not runnign good flowing heads, and only an 65mm TB...24lb injectors would be fine, not big at all and not too small..and i would do the fuel pump upgrade to an 190lph or 255lph fuel pump...also wouldnt consider that an drag car, just a stripped basic street car...
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old November 22nd, 2007, 11:30 PM   #3
sneezingfox's Avatar
sneezingfox is on a distinguished road
with new upper, you would benifit greatly with a fule pump upgrade, adjustable fuel pres reg and 24lbers
Old November 22nd, 2007, 11:35 PM   #4
13.64@101mph
+1 on AFPR...forgot to mention that
Old November 22nd, 2007, 11:36 PM   #5
The car is a drag car only, not street legal. It runs 8.10-8.15 in the 1/8th the way it sits. I forgot to mention it has 4.10 gears, locker, 26x10 MT slicks, a 3500 stall in it and I shift it manualy at 6200 (just shy of the rev limiter). Thats why I wanted the track heat (1500-6500 rpm) and not a street heat ( idle to 5500 rpm).
Old November 22nd, 2007, 11:38 PM   #6
13.64@101mph
i've always love that line...."i forgot to mention"....THAT HELPS!!!
Old November 22nd, 2007, 11:41 PM   #7
The car is nothing special, you can see a video of it on youtube. The link is:
My car can be seen in the close lane starting at about 1:03 till about 1:10. I believe I ran 8.89 (still had stock 2.73 gears at the time)
Old November 23rd, 2007, 11:47 AM   #8
tmoss's Avatar
tmoss is on a distinguished road
I doubt you'll need 24# with those heads............
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old November 23rd, 2007, 12:26 PM   #9
93 GT Hatch
12.68@112.57
superman5.0 is on a distinguished road
Send a message via AIM to superman5.0
change your intake and the 70mm will be good 24lbrs and 190lhp pump, if you get better heads look into a 255lhp pump, afpr makes air/fuel tuning as easy as turning a screw driver.
Old November 23rd, 2007, 02:24 PM   #10
nolife's Avatar
91GT, 88GT, 02GT
Doesn't the EEC4 learn around that? The o2 sensors will send the lean/rich condition and the computer will reduce/raise the injector pulse to compensate and the overall gain is nothing but a potential for the EEC4 to freak out, throw codes, or ignore things because they are out of range or fall back to a default air/fuel map which may not be the most ideal. That's the way I understood it but I could be wrong.
Old November 23rd, 2007, 02:43 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No you don't need 24lb injectors with that combo.
Threads Similar to: Do I Need 24lb Injectors?
Will Not Run On 24LB Injectors Euroeater95 94-95 5 November 4th, 2006 11:24 PM
What Fuel Presure For 24lb Injectors chadjones99 5.0 Mustangs 20 September 10th, 2006 11:32 PM
