Blown
Old November 23rd, 2007, 03:49 PM   #1
whitefox89's Avatar
whitefox89 is on a distinguished road
Blown
which block would be a better power plant turbos? roller 351 or roller 302, i want to stroke both so either a 342 or 408. i know the 408 would make more power and tq. but will a mid 90's roller 351 hold up to much power? if so, how much? i'd like to push it to a safe limit but i need to know where that line is at. and no... i dont want n/a. thanks for any help
Old November 23rd, 2007, 04:06 PM   #2
**Chris**'s Avatar
1989 LX Coupe
**Chris** is on a distinguished road
Stroked 351W FTW.
You'll have better luck with an aftermarket block, like a Dart Iron Eagle or a FRPP Sportsman block. But, if it's a stock block (2 bolt mains) make sure you spend the extra $$ for a girder.
You can see huge power #'s with boost... just make sure the rest of your drivetrain is up to the task.
http://img86.imageshack.us/img86/1241/notchbackskickass2zg0.jpg
7.87 @ 93 mph
Old November 23rd, 2007, 04:56 PM   #3
whitefox89's Avatar
everything will be set. i know what im doing... but i just wont have the extra $ for an aftermarket block right off. i plan on a main girdle and other upgrade.. just wanted to know if a 351 block would hold more power then the 302.
Old November 23rd, 2007, 05:17 PM   #4
**Chris**'s Avatar
1989 LX Coupe
Yes, it will. Not only hold more power, but it will make more power simply because of the extra displacement.
7.87 @ 93 mph
Old November 23rd, 2007, 07:19 PM   #5
whitefox89's Avatar
i know you cant give an exact amount.. but what kind of power are the windsor blocks ""guestimated"" to hold if i have a stout set of internals, crank, and motor work including stiffening it all up and balancing. i want to know what i should shoot for with a stock block. thanks
Old November 23rd, 2007, 07:36 PM   #6
1987 ford mustang gt
well see when shes done
i think its suppose to be somewhere around 700 at the flywheel
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old November 24th, 2007, 12:04 AM   #7
ryans88gt's Avatar
The late model F4 blocks aren't that strong. I definitely wouldn't be putting the boost to them in 408 form, think...a well prepped 408 will be making between 500-600 hp, add 8 lbs of boost and you are already well over what the stock block can handle (750-900 hp). At the very least get a early 70s non-roller block and put the $500 retrofit roller lifters in it, or any solid roller, or you can get a small base circle roller cam and use the late model roller lifters. The newer blocks have less material in the main webbing area and are more prone to cracking in those areas, but yes they are much stronger than a 302 still.
Old November 24th, 2007, 12:21 AM   #8
Speedstang302's Avatar
13.64@101mph
there right and wrong...the 351w would be cheapest and most practial way to go...but there is another way...you could go with an boss, dart or world 302 block, stroke it out, put on an single/twin turbo...but again "theres no replacement for displacement"
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old November 24th, 2007, 12:01 PM   #9
JBIGBOOTSY's Avatar
1990 LX hatch
Correct, but you have to be careful. Pre-72 351s are missing the extra .020 on the deck that the post 71 blocks have. You cant square them, or mill them at all. they are way stronger
Old November 24th, 2007, 04:35 PM   #10
baine21225's Avatar
ryan and speedstang and boosty got it right, not much left to say except i may wait until you have enough $$ for an aftermarket block, then you wont be limited
Old November 24th, 2007, 04:56 PM   #11
whitefox89's Avatar
its not that im worried about being limited. im looking for 550-600 boosted hp. just a preference with my budget. i currently have a 69 351 block in the car so im not sure... i may use it. i just figured i could sell it as is, and buy another cheap block instead of having extra internals laying around.
Old November 24th, 2007, 05:13 PM   #12
baine21225's Avatar
well the 69 block is going to be stronger than a mid 90's one
Old November 24th, 2007, 05:20 PM   #13
whitefox89's Avatar
alright then, i'll probably save some $ and use what i got for block.
Old November 24th, 2007, 07:38 PM   #14
Stangzilla's Avatar
Stangzilla is on a distinguished road
Stock 302 blocks dont like much over 500hp. You can run more but 6-700hp you will be runnin on borrowed time. Just so you know a stud girdle does very-very little in helping block strength. They are designed to keep the motor internals intacted in the block if you have a major failure. And you will have a major failure sooner or l8tr if you try to pump 600+hp through a stock 302 block..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old November 24th, 2007, 07:41 PM   #15
Stangzilla's Avatar
I beg to differ on that one, in some cases.. The no replacement for displacement part..
Old November 24th, 2007, 09:45 PM   #16
13.64@101mph
well more cubic inches = more hp...but there are some advantage's of building that smaller cubic inch motor...but you couldnt compare an N/A built small block stroker to an built big block stroker..those extra CI is just making it a beast...but you're are right..in some cases...
Old November 25th, 2007, 01:01 AM   #17
baine21225's Avatar
so he should just go with his 351
Old November 25th, 2007, 08:42 PM   #18
whitefox89's Avatar
thats what i plan to do... where can i find a turbo kit for a carb. setup.
Threads Similar to: Blown
Going Blown.... G.T. Rags Modular Mustangs 26 October 14th, 2007 08:12 PM
this motor is blown 8( flattusmaximus78 2005 - 2010 48 June 10th, 2007 03:31 PM
I'm Getting Blown! :o) MaverickMLFD371 2005 - 2010 11 December 4th, 2006 09:38 PM
Few Pics Of My Blown GT! matrixpuba Pictures 17 October 5th, 2006 11:07 AM
One Blown Cobra Cricket Multimedia 14 July 18th, 2006 08:09 AM
