The Classic 5.0 vs 5.8
Old November 23rd, 2007, 05:46 PM   #1
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
Red face
I really got to thinking yesterday. How heavy would a Dart blocked, or World Products blocked (stroked 5.8) be, compared to a Dart/Worlds stroked 302? Honestly, if its not much... i think i might just invest in a Dart/Worlds 9.500" block, and build something in the 400-430ci range, and go for 600hp on pump gas. I "was" really set on an 8.200" block, and building a 347-363.. or even something in the 380ci range.. but i find myself wanting more stroke.. and its not gonna happen with a 5.0 based motor. Am i looking at a significant amount of more weight? Or will the extra power/torque pick up the slack? Just curious.. this is a big decision, one that i'll have to live with for awhile. Thanks for any help.
Old November 23rd, 2007, 05:53 PM   #2
whitefox89's Avatar
whitefox89 is on a distinguished road
well i have a basic 357 windsor and i would never go back to a basic 302/306 block. if that gives you any idea.
Old November 23rd, 2007, 06:06 PM   #3
Goblin's Avatar
88mm
Thats awesome, but whats the weight difference? And i forgot to ask, whats the max amount of cubes that can be pulled from both the Dart and World products blocks, with both 8.200" deck, and the 9.500" deck.
Basically.... 8.200= Max CI? Dart/World. 9.500= Max CI? Dart/World.
Ive seen 470ci from the worlds.. im assuming thats the 351 block? Thanks again for the help!
Old November 23rd, 2007, 06:25 PM   #4
**Chris**'s Avatar
1989 LX Coupe
**Chris** is on a distinguished road
The weight difference is minimal, especially when considering the extra output of the bigger motor..
You would not even notice the weight difference at high speed lauches... maybe during low speed turns....but you'll like the extra power much better.
http://img86.imageshack.us/img86/1241/notchbackskickass2zg0.jpg
7.87 @ 93 mph
Old November 23rd, 2007, 06:59 PM   #5
Goblin's Avatar
88mm
This may possibly be the most un-important question ive ever asked, but is there a "sound" difference? Im not worried about it.. but im sure more cubes would probably make more noise... Do big windsors with full exhaust sound like really mean 5.0s? Or even better?
Old November 23rd, 2007, 08:15 PM   #6
whitefox89's Avatar
better specially with a cam windsor---><---302
Old November 23rd, 2007, 08:20 PM   #7
Goblin's Avatar
88mm
Sweet. Another question.. Im curious how well big inch windsors run with conventional 5.0 EFI intakes? For example.. a TFS-R upper and lower.. with say.. an 80mm TB.. Does the EFI setups run just as well as the carbed setups? Wish i didnt have to ask these questions! Thanks!
Old November 23rd, 2007, 08:28 PM   #8
whitefox89's Avatar
well you have to buy a specific 5.8 intake since its wider.
and in a nut shell yes im sure efi runs just as well... with alot more money and alot of tuning. this questions been asked alot so dont worry about it. but you will have less of a headache with carb i am sure. but if your dead set on efi, yes it can run just as well. hope that helps.
Old November 23rd, 2007, 08:41 PM   #9
Goblin's Avatar
88mm
Im not completely "dead" set on EFI. The main reason i'd like to stay EFI, is for emission purposes and visual inspection. Im not sure how the inspection here in FL works, but when i lived in AZ.. you couldnt run a carbed setup on a vehicle that had been equipped with EFI from the factory. I like the simplicity of carburetors.. but i want to keep the EFI for safes sake with emissions and inspection, plus i know EFI much better than carbs. Well see... i really hope EFI can provide the same numbers in N/A trim.
Old November 23rd, 2007, 10:10 PM   #10
TT86 is on a distinguished road
windsor---><---302
Umm.... a 302 is a windsor....
69 convertible:
302/ DART heads/Z303 cam/Vic Jr./ 650 DP
Tremec w/ 4:10s
86 hatch:
302/ Edel Al. heads/ F303 cam/
twin Garret T3 turbos
10 psi intercooled
52# injectors
MegaSquirt II EMS
http://www.youtube.com/watch?v=_urWMgS_IRQ
Old November 24th, 2007, 01:11 AM   #11
ryans88gt's Avatar
You could also consider the 9.2 inch deck height aftermarket blocks. You can run pretty big cubes with the right set up and have a slightly more compact package and lower center of gravity (also helps a little with hood clearance).
Old November 24th, 2007, 09:53 AM   #12
1/4-horse's Avatar
1987 LX vert/ 1984 LX 460
slow/stopped
1/4-horse is on a distinguished road
well you have to buy a specific 5.8 intake since it's wider.
I don't think that's entirely accurate. There are adapter kits out there to use 289/302 intakes on a 351 block, at least for carbed intakes. I'm not up on the efi stuff but I think it's the same bolt pattern, so they "should" work with them too.
Jay
I'm rapidly getting addicted to this Fox body Mustang thing.
Old November 24th, 2007, 10:54 AM   #13
ujslost's Avatar
Jay
I have never seen these adapter kits you talk about, but I would believe that once you buy the adapters, you could have just bought the proper intake to fit the 351. Plus adapters would call for additional gaskets, which makes the margin for leaking gaskets even greater, then if your really serious about power, you have to worry about that damn adapter and extra gasket being properly aligned and not obstructing air/fuel flow.
Old November 24th, 2007, 11:09 AM   #14
baine21225's Avatar
just buy an ls1, hahaha
Old November 24th, 2007, 11:14 AM   #15
69 convertible:
Tremec w/ 4:10s
86 hatch:
10 psi intercooled
52# injectors
MegaSquirt II EMS
Old November 24th, 2007, 03:02 PM   #16
408gt91's Avatar
408gt91 is on a distinguished road
im running a 408 with a victor 5.8 and 80mm tb its great!
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
Old November 24th, 2007, 03:23 PM   #17
1989 GT
Lauri is on a distinguished road
Dont'n know whats max, but World 371 shortblock is 8,2"
Old November 24th, 2007, 06:05 PM   #18
whitefox89's Avatar
you got my point.
Old November 25th, 2007, 01:24 PM   #19
Racinjason81 is on a distinguished road
i think a 351 based stroker would be better since the 302 based stroker would have to turn higher rpms to match the power a larger displacement engine.the larger engine moves more air and wont need to be spun up high to make power.
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old November 26th, 2007, 02:41 PM   #20
Goblin's Avatar
88mm
I definetly appreciate the responses! Baine.. trust me, ive thought about it! LOL Everytime i see a vette, i think "i wonder how fun that would be." Anyways, im still not completely clear on the weight difference...? And ive considered a 9.200" block.. but i really think i should go big, or go home if im going to do this. And hood clearance really doesnt bother me.. i'll just run a cowl hood to fix that problem. As far as the "adapter plates," i know theres plenty of EFI intakes that are 351w specific.. and will work great, im just curious on the power differences between EFI and Carb'd on a similarly built combo. Thanks for the help everyone!
Threads Similar to: The Classic 5.0 vs 5.8
classic pony 68pony New Members Introductions 9 January 6th, 2010 10:25 PM
Classic Wheels 05MUSTANG4.0 V6 Mustangs 1 June 27th, 2007 11:57 PM
classic DragonFreak Videos 3 April 8th, 2007 12:31 AM
Classic Fairlane's 68pony The Clubhouse 6 March 4th, 2007 07:08 PM
