Street/Strip Project
Old November 24th, 2007, 11:21 PM   #1
motorhead6776's Avatar
2003 Mustang
15.00@93.06
motorhead6776 is on a distinguished road
Send a message via AIM to motorhead6776
ok so i have the oppertuinity to buy a 1991 foxbody with a 12 point cage and no motor or trans. i would like to build a 10 second car to run on the weekends at the local track. i was looking into getting a 351 from a junkyard and machining it to a 408, 418, or a 426. from what ive seen it requires 550 to 600 hp to run mid 10's. my question would be how much would it cost to do this with a bore'd and stroke'd junkyard 351. also how much would the transmission cost and what would it be.
Old November 24th, 2007, 11:25 PM   #2
1987 ford mustang gt
well see when shes done
question is hpw much do you have 2 spend?
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old November 24th, 2007, 11:33 PM   #3
2003 Mustang
15.00@93.06
i currently have 3k that i can spend and should have another 5k on top of that by the end of the summer. that i figured will be spent while im assembling the car.
Old November 25th, 2007, 12:10 AM   #4
2003 Mustang
15.00@93.06
i was looking around at cylinder heads and they seem to vary from 1k to 20k for a set. so i was wondering what kind of flow numbers would i be looking at to make 600 hp on a NA motor running 93 or 110 octane.
Old November 25th, 2007, 10:00 AM   #5
2003 Mustang
15.00@93.06
bump
Old November 25th, 2007, 10:03 AM   #6
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
$20k for cylinder heads? lol
MM 1 am boner crew
Cars and mod list in garage
i like veiny meat sliding between my buttcheeks
Old November 25th, 2007, 10:22 AM   #7
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
no kidding. do they drive the car for you?
2008 Acura TL-S - 2008 Honda Pilot EX-SE
Old November 25th, 2007, 11:02 AM   #8
1990 5.0 LX Notch
flamed 98 gt is on a distinguished road
WOW 20k for heads???? Also stroking out a Ford factory 351w block will only hold up to about 700 hp before it splits like the 302. If you are going to want more power down the road I would intvest in a World or Dart block (9.500 beck height). Other then that the 351w will be fine.
Old November 25th, 2007, 11:58 AM   #9
Racinjason81 is on a distinguished road
look into a set of 225cc heads such as AFR or Trickllow and if you want to go the extra yard get em ported by total engine airflow.you could also get those heads already ported from TEA for a little cheaper
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old November 25th, 2007, 12:01 PM   #10
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
LMAO...hell for 20K they'd better...and they better run 6-7 second quarters while they're at it..
Old November 25th, 2007, 12:46 PM   #11
2003 Mustang
15.00@93.06
Ford Performance Solutions
yeah those are the 20k cylinder heads. i think ill stick with the factory block beacause of my budget, and i know theres always those annoying little problems that start to add up.
Old November 25th, 2007, 12:48 PM   #12
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
holy FUCK!
i thought you just made a typo, lol
MM 1 am boner crew
Old November 25th, 2007, 01:01 PM   #13
holy FUCK!
For 20K you could have a couple nice foxbodys runnin 11 second quarters or one "REALLY" nice fox under pressure...Those heads are CRAZY! You'd need one hell of an intake and exhaust
Old November 25th, 2007, 01:19 PM   #14
2003 Mustang
15.00@93.06
lol! so i was back to looking at the bore kits and they range from 306 to 427. and i was wondering if i had a rebuilt junkyard block bored to 427 would that be strong enough to run say a 100 shot of nos? prettymuch what im wondering is what would be the best balance be between strength and displacement?
Old November 25th, 2007, 01:20 PM   #15
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
351W bored and stroked to 408.. that's what i would personally do
MM 1 am boner crew
Old November 25th, 2007, 01:33 PM   #16
woody1 is on a distinguished road
The 408 is easiest for 99% of guys to build. When building a 427 with the 4.170 crank you need to watch the big end of the rod gets pretty high up in the cam tunnel and depending on cam, may need to clearance the big end of the rod. If none of what I said makes sense to you or you dont have the experience build a 408
Old November 25th, 2007, 03:32 PM   #17
2003 Mustang
15.00@93.06
ok so if i went with a 408 and afr 225cc heads what should i do for an intake manifold?
thanks for all the help so far too!
Old November 25th, 2007, 03:47 PM   #18
super vic
Old November 25th, 2007, 03:53 PM   #19
built351w's Avatar
1979 mustang 5.0
hopefully 11's when complete
built351w is on a distinguished road
OK you need to do some more homework before you just go buy a car! I did the same thing you are doing, I'm 17 now and I started building my engine 351w back in February.
Believe me when I tell you there are so many things that you haven't even considered into your cost factor!!! Engine work is expensive as hell, certain parts are too. If you have 2K after you buy the car that's enough to get started on the engine, go find one and plan out what your going to do to it, price out and buy all your internal parts then give it to the machine shop. While the engine is being built get to work on the car. Does it need paint or bodywork? Set the car up drags, springs, shocks, cross members, transmission, bell housing, tires and wheels.....ect
It's good that you want to do this like I did, but keep in mind a 10 second car is probably going to need nitrous or a supercharger or turbo, you could do it n/a but the engine would basically not be street friendly in the least.....
Old November 25th, 2007, 03:56 PM   #20
most of what you say is true, the last part is definately not. A 400 inch pump gas windsor is no problem on the street and will idle at 900rpm if you know what works. If this was 1990 I would agree with you but with the cylinder heads and cubic inches we have today, 10's N/A on a pump gas street car at 3000lbs is easy.
Threads Similar to: Street/Strip Project
My New Street/Strip Car 1SLO85 Pictures 19 November 24th, 2007 10:49 AM
the best 5.0 street/strip intake manifold!!!!!!!!!!!!!!!!!!! kngkahious 5.0 Mustangs 10 May 24th, 2007 06:05 PM
street/strip angermgt 5.0 Mustangs 13 May 11th, 2007 11:52 PM
street/strip DOHC build help hotrod lincoln Modular Mustangs 1 February 5th, 2007 10:52 AM
For street/strip man_of_war2081 99-04 8 December 30th, 2006 12:09 AM
