Stroking Basics - Page 2
Old April 22nd, 2009, 09:41 AM   #21
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by detroitstang View Post
Im current trying to create a monster out of my 87 foxbody. i was wondering if any one could give me a hp prediction or tip for my project. this is what im working with so far.
331 stroker
soild crane z cam #443512
490 int/504 exh
268 in/274exh
duration@.050 lift 218 in /274exh
lobe seperation 112 degrees
rods scat 5.4 i beam rods
pistons kieth black flat top (non forged)
melling high volume oil pump,
double roller timing chain
280z flex plate
0-28 oz balancer
scat stroker 3.25 crank
Pro Comp Aluminum Heads 60cc combustion, 195cc intake runners
still havent decided on an intake... plan on driving daily. any input?
"Everyday in Africa Gazelle Awakes and knows he must run faster then the Lion or he will be eaten. Everday in Africa a Lion awakes and knows he must run faster the the slowest gazelle or he will starve to death. It doesnt matter if you are the Lion or the Gazelle all that matters is when the sun raises your ass better be running."
Start a new thread. This thread is not for horsepower questions, it is for stroker info.
Old November 9th, 2009, 12:44 PM   #22
Hydration's Avatar
1987 5.0 Mustang
Hydration is on a distinguished road
Good info, I'm still debating on stroking a 302 or destroking a 351.. opinions?
Old November 16th, 2009, 10:07 PM   #23
1988 Mustang GT
Dstang88 is an unknown quantity at this point
back to he comments before about the rod length ..... it does matter because the better the ratio the means your motor works better together and you know what shit you have in your motor.... it also means more compression and hp's
Old November 21st, 2009, 01:07 PM   #24
96_5.0_Mustang's Avatar
96_5.0_Mustang is on a distinguished road
need help
Im wanting to stroke my 302 to a 347. Any suggestions on kits an what rod length use??? An will my top end work good w the extra cubic inches??
"A large cam will do nothing for you if you can't use it. If you do your combo correctly, you can have both the lope and power.Think of it this way, buying a pack of magnum condoms may be impressive, but whats the point if you can't use them?"
Old November 21st, 2009, 07:09 PM   #25
1988 Mustang GT
That depends on if your heads cam and intake feed it im sure the more radical you go the more its going to like it.... i also am looking to stroke mine if you find any good kits let me know or post them.
Old November 21st, 2009, 09:06 PM   #26
well afr heads should feed it from what the engine shop says. an the intake is port matched an the cam is pretty radical as is. it lopes pretty good.
Old November 21st, 2009, 09:09 PM   #27
rpmmachine.com has a all scat kit and is the cheapest ive found so far. what topend are you useing dstang88 and are you efi or carborated?
Old November 24th, 2009, 12:43 PM   #28
1988 Mustang GT
ill be using a gt40 or explorer and gt40 heads and an e cam is whats planned also gonna run spray and it is still efi...... im getting a cobra intake with the heads but i think the gt40 will work just as well and have a little bit more of a sleeper look to the non mustang peeps. and ya im sure your heads will flow plenty of air lol but everybody uses those im sure they work very well i just want to be a little different and i got a deal on my heads soooo.... why not !
Old December 12th, 2009, 03:57 PM   #29
Zoe Pound's Avatar
Zoe Pound is on a distinguished road
sounds good
Old January 26th, 2010, 02:12 AM   #30
1989 Mustang GT
Young Rand is on a distinguished road
so which is better for a everyday driver 306,331 or 347?
Old January 27th, 2010, 01:17 PM   #31
Zip Your my Hero....
fastback lover's Avatar
1988 Mustang LX
N/A
fastback lover will become famous soon enough
That is some really good info. I have never thought about strokin an engine but now I am really going to have to reconsider for the car. Thank you guys.
Old January 28th, 2010, 09:29 AM   #32
Rusty105 is on a distinguished road
It's not as easy as that.
You could build a 306 that is nice an docile on the street, or it could be an animal, same goes for the other combos. Street manners has more to with the heads, cam and intake. Generally, you will get the same HP level, but at a lower RPM, with more cubes.
Rusty
Old March 31st, 2010, 11:05 PM   #33
Kent535's Avatar
1987 Mustang LX 351W
Kent535 is on a distinguished road
Old April 8th, 2010, 05:03 PM   #34
1988MustangGT is on a distinguished road
this is cool
Old June 9th, 2010, 12:59 AM   #35
twinky's Avatar
1982 mustang gt
twinky is on a distinguished road
someone asked if you could put 289 heads on a 347. they are on mine. the engine was in my buddys car and was bad as hell!! the heads were decked and when my uncle was alive he ported the heads and put bigger valves in them they flowed awsome. i put 3" exhaust on it with race mufflers. still needing to time it but having a hard time.
mike
Old June 9th, 2010, 01:29 AM   #36
SPLAudioHz is on a distinguished road
There is a lot of good reading on here. I think there should be some updated stroker articles. After spending a fair share of time on the phone and internet with techs from AFR, Edelbrock, Scat, and Ford Racing getting educated on the right setup for me. I brought all of this info (oil loss with the 347, durability of piston rings, skirts, etc...) to the table for discussion and problem solving. As of May of 2010 this is what I have been schooled on. According to the mentioned companies Edelbrock has designed the best head to manifold setup/combo for the 302/351W block. AFR did compare their heads to edelbrock's, but on a much higher performance level (drag/stock car level). After an hour on the phone with edelbrock it was decided that the performer rpm 5.0 II combined with a cylinder head from the Edelbrock XT (Xtreme Series) line. The choice on head depends on what I want out of the car, so I am not 100% on my needs yet, but they assured me any of them from this line would be just right for a 347. The tech from edelbrock also suggested a 42lb injector. Once I asked about cams he directed me to Ford Racing, or Crane Cams. I spoke with a tech from both companies. I am still waiting on an email response from Crane to include info and options on cams. FR suggested a X or a Z303, but again it is all depending on my application. As for the Stroker kit, I spent a great deal of time on the phone with an engineer from scat. Really nice guy, and it seemed like he had all day to answer my questions. As for the oil loss answer, they designed a "Gutter Ring" (his terminology not mine) that sits just above the wrist pin so that oil is retained more so than before. I asked him "Does it stop the oil seeping?" He responded, "No, you can expect to lose approx. 1/2-3/4 of a quart every 3-4k miles". This is substantially better than the old designs that did lose more oil. I then asked about the skirts as well as the possibility of this stroke upgrade lessening the lifespan of the engine. He when into the whole long story of how application, treatment, and abuse plays a very large role in the life of an engine (i.e. boosting, racing, etc...). The bottom line is (from his perspective) if you run a Hyper dish forged piston with Chrome Alloy rings keeping the compression at approx 64-70cc along with their 302-347 stroker kit the engine will make a "Solid, dependable, and enjoyable daily driver". He took into consideration the information I acquired from the other companies.
Over all I have found "My Build", but it took lots of questions, research, and willingness to have an open mind. I learned that the most expensive is not only the best and that it is all "Proper application and combination of parts". My fear of building a ticking time bomb has perished and swayed my decision between the 331 and the 347 stroker kits.
I hope this info can be helpful to any of you out there. I am not a professional in the area of auto mechanics, that is why I called all the companies I did. I say this so that members out there with questions to my build will keep many of their suggestions and comments at bay as I will not be able to answer them efficiently.
Hope my efforts may benefit you,
Jesse
Old June 9th, 2010, 09:08 AM   #37
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
mike
Sure, you can put 289 heads on a 347. They will physically bolt on but are far from ideal for 347 cubic inches. Ported or not, they are still a factory Ford cylinder head. This engine being "bad as hell" in your buddy's car is a matter of opinion. What did it run in the 1/4? If you think it was bad as hell with factory heads, you'd have an accident in your pants with a good set of aftermarket heads on it.
Old June 9th, 2010, 09:34 AM   #38
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Jesse
There is a lot of crap in this post. 347s don't burn oil, period. They are no different than any other engine. I've owned more of them than you do underwear. Never burned a drop of oil. If someone at Scat actually told you that crap, it was a sales pitch.
As far as Edelbrock, AFR, Ford Racing and Scat "educating you" on the right set up......I have to pick this apart so someone doesn't read your post and become misinformed. When you want advice on the right combination, you call an engine builder not a manufacturer or salesman. Some of this crap I don't even know whether to believe it was a real conversation or not. If any of it actually took place, then these are good reasons to never call tech support at any of these companies. Why does the Edelbrock tech recomend a 42lb injector in a 347 when 30lb injectors would be plenty for the combination listed? And then the he recomends the competition for a camshaft? I doubt it. Fyi, I would not use a Ford Racing cam. I'd probably use the stock cam before I use any of the xyzpdqabc Ford Racing cams. The best head and manifold are relative to the combination. What is best for one combination might not be the best for the next combination. Every company will tell you they have the best cylinder heads, cams, intakes, etc. The people that will have answers that are worth anything are not the manufacturers, but the people that actually have used the parts and dynoed or ran down the track and have some real world numbers.
Old June 9th, 2010, 01:00 PM   #39
mike
After the beating you took over on 4-eye regarding this, I wouldn't be spouting off too much about 289 heads on a 347
Rusty
Old June 9th, 2010, 01:53 PM   #40
I only took the info I was provided and posted it. That is all. You can call it crap all day and it doesn't matter. If you would like to question my post PM me and I will be happy to give you the names of the people I spoke to and the numbers along with extensions. I did not speak with any build shops, only with two owners of stock car racing teams. I will admit they do not have as many engines as I "have underwear", but that is nor here or there.
You seem to be really upset here and being that you have so may posts and I have so very few I can see the type of person you are by the comment you left. I have no reason to provide false information in this site, for some insecure reason you feel I do. I will no longer be returning to this site and I can anticipate two things: You will provide a comment explaining your joy for someone no longer on here providing "false" information, and second a moderator will remove this post. By the way I never said 347s "burn" oil. Only that the location of the wrist pin allowed for oil loss. So, please, see a professional, get on some type of psychotropic medication, read members posts s-l-o-w-e-r, and use some tact when you reply.
Threads Similar to: Stroking Basics
Stroking a 306 Tony_90fox 5.0 Mustangs 48 March 20th, 2011 11:00 AM
The Basics For Beginners... a help-guide for newbies Ninjawafers! V6 Mustangs 23 July 4th, 2008 10:42 AM
Mod Motor Basics Schraders 99-04 15 March 30th, 2007 04:17 PM
turbo basics and what not 232stang V6 Mustangs 30 January 27th, 2007 01:41 AM
mustang suspension basics 99mustang232 General Tech 2 March 16th, 2006 08:58 PM
