About Stock Block. Answer Quick Please
True or false, the stock 302 block in the 93 gt will run chances of breaking at 500 hp.
=) Need this confirmed. |
95 Mustang GT
you run chances at stock HP depending on driver and car etc. but think the max you wanna take your block to is 550 range
1987 ford mustang gt
well see when shes done
i wouldnt even go that far 500 at the most
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
95 Mustang GT
just didnt want him to feel like he was right....lol
alright guys close the topic.. no more posts. :-)
1st was 73mach, now 97
old mach1 12.20@ 117mph
if you race it every weekend, probably not.
but i think if you use a main cap girdle, about an inch of hardblok, 1/2" arp main and head studs, along with a quality line hone, bore and deck plate hone, it will be fine for moderate use. |
that dont make the block any stronger it just keeps the two halves of the block together and does not allow the crank to fall out the bottom
guess you're right.
how about those new boss blocks? anyone use them much, yet? what are they worth in the US? |
they are about 1700 bucks and i dont know much about them if i was going to do a build that needed an aftermarket block it would be a man o war,iron eagle or sportsman
my work in progress is based on the siamese bore 351svo,(M6010-w351) but
i figure i'll be a long way from pushing the limits of the block. currently stock bore x stock stroke i'm hoping to put a year of running on it, hopefully season the block a bit before i have enough$$ to buy a 4.125 x 3.75 rotating assembly in a year or so. OR i could put hardwood floors in.. tough choices |
#12 | |
keep the peace? good plan.
you're right. in her quiet, unassuming way, she always gets what she wants somehow anyway. but cars are like crack. all this neat stuff is just a click of a mouse away.. |
#15 | |
after 15 yrs wedded bliss, peace and quiet is reward enough..
it might cost me a floor, though.. |
what does the little green light mean, under "Posts:" it says distinguished road.wtf?
13.64@101mph
the new ford boss 302 is actually pretty good..its limit is somewhere over 1000hp...its compatible with most if not all parts that fit stock windsor 302s...and for being the less expensive out of all so i dont see why they wouldnt be too bad...also they have stronger nickel content allowing you to bore out the motor more than like .40 over like the stock block..they can do like .70over or so..thus meaning the block in 1 peice will last longer becuase you can get it bore .30 over to clean it, and then later .30 over again to clean it again..if you dont blow it up first
#19 | |
13.64@101mph
thats what i was getting at..didnt know the exact limit of bore...and i knew it was 1300 or so...but over 1000 sounds coooler...1799.99 is just the block..no internals, not decked, honed...the interals could be as low as $750...
Threads Similar to: About Stock Block. Answer Quick Please
| Need quick answer on Rim size and tires for a new Mustang | silvel2edge | 2005 - 2010 | 5 | May 20th, 2007 04:07 AM |
| I NEED ANSWER QUICK PLEASE | stang94 | 5.0 Mustangs | 4 | March 15th, 2007 09:52 AM |
| Need an Answer quick! | 68 dlxcoupe | 96-98 | 3 | February 6th, 2007 11:33 PM |
| Need answer QUICK! | mystang0673 | 99-04 | 1 | February 1st, 2007 05:16 PM |
| Stock Cobra Block and GT Block the same?? | bbrewer03 | 96-98 | 2 | August 26th, 2006 01:31 PM |
