Head install question: Setting valves before starting?
Old August 28th, 2006, 12:26 AM   #1
mikes93fox is on a distinguished road
I am looking for tips on setting the valves on a set of new pedestal mount heads? I've read you can start by tightning the bolt for the RR till the rod will not spin in your fingers. Then, take a torque wrench and wrench the RR bolts to 18-20 lbs. Just curious if any of you guys have any tricks to setting the valves before starting the motor? Thanks in advance.
Old August 28th, 2006, 11:25 AM   #2
stanginfection is on a distinguished road
On pedistal Rockers the bolt gets torked not adjusted. Adjustment comes from measuring the preload on the lifter and using a shim between the rocker and the pedistal to make adjustmets.
Old August 28th, 2006, 05:52 PM   #3
IcantDo55 is on a distinguished road
yep.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old August 28th, 2006, 11:50 PM   #4
I realized that the bolts are torqued on the pedestals and that you shim them for adjustment. Just curious if these torque specs sound right to any of you.
Threads Similar to: Head install question: Setting valves before starting?
PROJECTOR HEAD LIGHTS INSTALL!!! 04gt 99-04 7 October 10th, 2007 11:14 PM
Just finished Head and Cam install, do i need a new tune? MySallyMI 99-04 22 February 28th, 2007 08:34 PM
head unit install (yes another 1) BlackIce Audio/Video 4 February 22nd, 2007 05:34 PM
Need Help With Head Unit Install Teggy_Boy Audio/Video 1 January 18th, 2007 07:54 PM
Quick question - Adjusting valves absolutezero 5.0 Mustangs 1 July 26th, 2006 02:37 PM
