Auburn Pro vs Detroit Locker vs ?
Closed Thread
Old November 30th, 2007, 11:01 AM   #1
skidoo's Avatar
1st was 73mach, now 97
old mach1 12.20@ 117mph
skidoo is on a distinguished road
what do you guys think of the auburn diff? i saw one at a shop that was all apart, and where the cones sit against the case, it was all grooved and chewed out. no clutches, just metal on metal.
another guy with a mud pulling truck had exploded the case..it cracked where the pinion shaft went in. i only saw this AFTER forking out $$$ to buy one. its in the car now, but never been run yet. i would think slicks on a drag car would be more stressful than mud, right?
Old November 30th, 2007, 01:18 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Good heavy duty differentials don't use clutches. Most of the stuff out there uses cones or ratchets.
Auburn and Eaton make good stuff for street/stip cars.
Old November 30th, 2007, 01:22 PM   #3
The Razor's Edge
White Thunder's Avatar
if the stangs come with a posi is there really a need for a locker...how much would it help you....or is it one of those things that helps at 500+hp
founder of the FTN Club
Old November 30th, 2007, 01:32 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes. The factory clutch type traction lock is not a heavy duty piece. If you do a lot of drag racing an aftermarket piece can save some headaches. On the plus side the factory piece is easily rebuilt and there are some tricks to make it work a little better.
Old November 30th, 2007, 01:36 PM   #5
The Razor's Edge
thanks your a good guy to count on for advise with experience....
Old November 30th, 2007, 01:48 PM   #6
ryans88gt's Avatar
The factory piece will hold quite a bit of power with the carbon disk upgrade (the are used in the 03-04 cobras, so...) and packing it with four disks instead of three. They will handle quite a bit of power, but plan on rebuilding them every few years if you spend a lot of time at the track. It's not really a big deal, if you don't mind setting your vavle lash twice a year, you shouldn't mind rebuilding your track-lok every year or so.
Old November 30th, 2007, 01:53 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Setting valve lash takes 15 minutes. Pulling out a traction lock, rebuilding it and reinstalling it takes about 4 hours. Sometimes you should just keep your mouth shut so you don't sound so foolish.
Besides, how do you upgrade your factory traction lock to accept a good axle?
Old November 30th, 2007, 01:56 PM   #8
The Razor's Edge
the battle begins!
Old November 30th, 2007, 01:58 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
the battle begins!
Yep, he is like a teenage boy with some of his comments.
Old November 30th, 2007, 02:05 PM   #10
The Razor's Edge
i seen the last few....entertainment at its best
Old November 30th, 2007, 02:54 PM   #11
skidoo's Avatar
well. i feel a bit better now, an auburn or a detroit locker, pretty close in $$, so i was just second guessing if i made the wrong choice, but the 31 spline axles is exactly the reason i upgraded the posi, anyhow. never had a detoit locker before.
thanks for the info.
Old November 30th, 2007, 03:27 PM   #12
White 89 is infamous around these parts
Go with a locker.... Auburns are junk I already broke my auburn. I got a one wheel wonder when doing a burnout at the track and am going with a detroit locker. I run Street ET's at all times so my Posi did take alot of abuse.
1989 mustang GT 5.0
Old November 30th, 2007, 05:45 PM   #13
gotboost562's Avatar
gotboost562 is on a distinguished road
Send a message via AIM to gotboost562 Send a message via Yahoo to gotboost562
I plan on using an Eaton. It already has the carbon-fiber clutches.
Old November 30th, 2007, 07:12 PM   #14
flamestang's Avatar
flamestang is on a distinguished road
I had an aburn pro for a couple of years and didn't like it from the day it was installed.It popped and chattered with 2 bottles of friction mod and car would not kick sideways it would slip.I now have a FR trac lock and have no complaints.
Old November 30th, 2007, 07:18 PM   #15
1987 ford mustang gt
well see when shes done
hope you like driving that locker on the srteet
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old November 30th, 2007, 07:33 PM   #16
flamestang's Avatar
I coudn't find cluthes for the aurburn an FR clutches are avilable
Old November 30th, 2007, 08:48 PM   #17
ryans88gt's Avatar
I don't know how you figure some of the shit you say, but the factory track lok out of an 03/04 cobra is made for 31 spline axles, cost $200 and is made to hold 400+ hp before you upgrade to 4 clutches per side.
It takes me about 1 hour to rebuild my trak-loc. Drop the cover, take out the pin, knock the clips out, pull the axles 2 inches, knock the spring out, put new clutches in, measure clutch pack and grab the correct shim, put them back in, followed by the spring, clips, and pin. Put cover on and fill the diff. I guess if it is your first time or only have one arm it might take 4 hours...
My current diff hasn't needed a rebuild in two years...
Old November 30th, 2007, 08:50 PM   #18
ryans88gt's Avatar
By the way, if you are pulling out a trac lok to rebuild it, that is just retarded they are cake to rebuild while still in the rear.
Old November 30th, 2007, 08:55 PM   #19
1965 Mustang Fastback
nba1341 will become famous soon enough
who will win this battle of the ages?
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old November 30th, 2007, 08:57 PM   #20
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Not you ^
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Closed Thread
Threads Similar to: Auburn Pro vs Detroit Locker vs ?
Detroit Locker Compatible With C-Clip Axles? C MY 4D 4V / SVT 0 November 12th, 2007 07:25 PM
Auburn/t-loc difference? 2000Mustang The Clubhouse 4 September 24th, 2007 05:11 PM
auburn gear ECTED usmcsawgunner 5.0 Mustangs 5 May 26th, 2007 04:01 PM
Detroit Locker Q. Flomaster_Knockoff 5.0 Mustangs 10 April 28th, 2007 12:10 AM
Auburn ECTED 97prosnake 96-98 0 January 7th, 2007 11:58 AM
