5.0 Base Idle Reset
LinkBack (47) Thread Tools
Old December 1st, 2007, 12:58 PM   47 links from elsewhere to this Post. Click to view. #1
TurboLX's Avatar
1988 Mustang LX Turbo
5.0 Base Idle Reset
Base Idle Reset Procedure
1. Clean TB with carb cleaner and nylon brush (toothbrush size). Engine off, fully open TB blade and spray/brush TB until all gunk and oil residue is cleaned.
2. Allow to dry, or close TB blade and start engine until it clears all carb cleaner fumes/liquid.
3. Let engine idle...if it doesn't, increase idle speed via TB stop screw until engine stays idling on its own.
4. Disconnect IAC valve, if engine dies repeat 3 with IAC disconnected.
5. Set idle speed to the lowest setting possible between 650-850 rpms with IAC disconnected. It is key to use the lowest possible to prevent idle surge, rolling, etc once the IAC is connected as follows.
6. Turn engine off, and reconnect IAC
7. With Ign On Eng Off, check TPS voltage output....if it's between .8vdc - 1.0vdc, it's OK. This voltage check should be done between the Green and Black wires at the TPS side connector as shown in the pic below (FYI: Green = TPS Signal, Black = SIGRTN, and Orange = VREF)....(-) terminal of the DVOM on the Black wire and (+) terminal on the Green wire.
8. Disconnect battery (-) for 3-4 minutes.
9. Reconnect battery, start engine, allow it to idle for 2-4 minutes to confirm setup,
10. If idle speed falls too low or stalls, increase idle speed via the TB set screw a little at a time.
11. Turn engine off for 20 seconds, re-start engine and repeat 9 - 11 if required.
12. Reconfirm TPS output is within the .8vdc - 1.0vdc range optimum range.
NOTES:
1. No need to reset ECM KAM (reset computer), the TPS minimum value used for idle control, is reset automatically by the EEC-IV every time the ign is cycled on-off for 20 seconds-on.
2. If the TPS output is within 6vdc - 1.1vdc, it's still acceptable, since no TPS failure codes will be generated, and it falls within the EEC-IV .5vdc - 1.19vdc working range.
13. Allow a 10-20 minute "relearning" period under normal driving conditions (drive cycle).....you're done!
As original from Joel5.0 of index
Old December 7th, 2007, 04:16 PM   #2
patwrecked is on a distinguished road
make sure also to make sure your timing is correct. playing with the idle speed can effect when you reach full advance
Old January 7th, 2008, 01:35 PM   #3
1966 Mustero
12.50
Mustero is on a distinguished road
If all that still doesen't help try adding Ford part number F2PZ-9F939-A. This is a factory ford "Engine Idle Air Kit" That gives you additional adjustment range in your Idle speed without changing throttle angle.
Old January 14th, 2008, 12:37 PM   #4
MustangSallee's Avatar
1994 Mustang 5.0
MustangSallee is on a distinguished road
I know that this post has probably been here a while but I would still like to say that it is extremely useful and I appreciate it being here for reference. Also I would like to add on 94-95 models the TB screw isn't a screw but a stud. I suggest to avoid hurting the threads on it with a set of pliers or something else trying to adjust it, but instead grab a hack saw and gut a small groove in the top [deep enough not to strip] and use a flat-head screwdriver like you normally would on it. Worked like a charm for me, it may take some penetrating oil if the stud/screw is seized up. Just though I would put my 2¢ in
Old January 22nd, 2008, 12:06 PM   #5
1989 5.0 fox
11.6
fastest-stang-round is on a distinguished road
yea u wana makesure to do that!
Old February 24th, 2008, 08:48 AM   #6
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
question..i got a 94 gt and i just replaced the iac and the tps and cleaned the throttle body and my idle is all screwed up it idles really high, but i think i gotta fix this fuel problem first..but what if you just cleaned it, put a new TPS and IAC on and put it back together?
Cohagan Engineering, Inc.
Old March 6th, 2008, 12:36 AM   #7
omspray is on a distinguished road
nice car
love that color
Old March 20th, 2008, 06:42 AM   #8
DennisChow is on a distinguished road
O?
Old March 30th, 2008, 06:55 PM   #9
workhorse302
Guest
Posts: n/a
oh so thats why my idle is bad
Old April 24th, 2008, 03:51 AM   #10
Hunt_chevs's Avatar
88 Gt
Not Slow
just did the reset,.... positive results!! wish i could get it slightly lower idle, but doesnt seem to want to....
Old August 13th, 2008, 06:28 AM   #11
t5mustang is on a distinguished road
great , thanks for iofo
Old September 14th, 2008, 11:57 AM   #12
Zip Your my Hero....
fastback lover's Avatar
1988 Mustang LX
N/A
fastback lover will become famous soon enough
Good info here.
Old September 21st, 2008, 09:48 PM   #13
jjperl is on a distinguished road
Thanks for all the great info!
Old October 10th, 2008, 03:21 PM   #14
BORDEN's Avatar
91 lx convt
14.02@100
BORDEN is on a distinguished road
i wish i woulda read this about a year ago when i had my idle problem!!!!!
Old October 20th, 2008, 05:31 PM   #15
91black#7 is on a distinguished road
Good info
Old November 3rd, 2008, 07:40 PM   #16
1990 Mustang GT
rocket is on a distinguished road
could this be part of the problem i am having, the car idles fine until i turn the air or defrost on, then it drops idle and bounces up and down, occ stalling. happens even sometimes when driving and if push clutch in, can die. If air off, runs great. Not sure what is causing it. The volts also drop with idle.
Old November 25th, 2008, 03:28 PM   #17
fox bodies rule is on a distinguished road
need a F2PZ-9F939-A TABP?
If you have followed all of the hints above, used the idle adjustment procedure in the tech section and have determined that you still need the Throttle Air Bypass Plate (TABP air adjust spacer plate) you can get one directly from TOMCO for $22.91 plus shipping. I think that mine came to ~$30 delivered by the guy in the brown truck. It is their part number 8491. I had one on my '88 that was the Ford part and have this one on my
'90 and they are the same part only Tomco's is a lot less expensive. For you lucky stroker 347 guys and those who have a 351 or bigger, be sure and read the "idiot sheet" that comes with the plate, it is very thorough and easy to understand but you need to pay special attention to the modification for bigger displacement engines. I linked to their .jpg file of the part if you want to look at it and see just what everybody is talking about. Happy idling.
[URL="http://www.tomco-inc.com/admin/ProductImages/8491.jpg"[/URL]
Old January 18th, 2009, 02:25 PM   #18
BEASTstang's Avatar
BEASTstang is on a distinguished road
it works ,just follow instructions
Old January 29th, 2009, 08:33 AM   #19
aooinn is on a distinguished road
thanks
thanks a lots
Old February 21st, 2009, 06:12 PM   #20
and for the people that need a picture...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/44747-5-0-base-idle-reset.html
93 mustang wont stay on idle - Northern California Ford Owners  This thread Refback December 26th, 2011 09:14 PM
89 gt is mass air too big? - Northern California Ford Owners  This thread Refback December 7th, 2011 01:36 AM
89 gt is mass air too big? - Northern California Ford Owners  This thread Refback November 27th, 2011 11:54 PM
just installed a b-303 cam a few questions - Northern California Ford Owners  This thread Refback October 28th, 2011 07:41 PM
93 mustang wont stay on idle - Northern California Ford Owners  This thread Refback October 28th, 2011 03:08 PM
how to dial in a TPS on sn95 throttle body?? - Northern California Ford Owners  This thread Refback October 22nd, 2011 08:26 PM
93 mustang wont stay on idle - Northern California Ford Owners  This thread Refback October 18th, 2011 10:02 PM
93 mustang wont stay on idle - Northern California Ford Owners  This thread Refback October 17th, 2011 11:52 PM
rpms low on idle! help! - Northern California Ford Owners  This thread Refback September 17th, 2011 08:40 PM
how to dial in a TPS on sn95 throttle body?? - Northern California Ford Owners  This thread Refback September 17th, 2011 04:41 PM
Carb To EFI Conversion Write Up - MustangForums.com This thread Refback August 12th, 2011 12:51 AM
just installed a b-303 cam a few questions - Northern California Ford Owners  This thread Refback August 11th, 2011 03:41 PM
just installed a b-303 cam a few questions - Northern California Ford Owners  This thread Refback August 4th, 2011 01:34 AM
truck keeps stalling - FSB Forums This thread Refback July 30th, 2011 02:48 AM
Lets play guess that plug and where it goes. - Page 2 - FSB Forums This thread Refback July 29th, 2011 11:41 AM
Iac - Northern California Ford Owners  This thread Refback July 26th, 2011 03:08 AM
Iac - Northern California Ford Owners  This thread Refback July 25th, 2011 06:15 PM
To seafoam or not? - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback July 7th, 2011 11:23 PM
Wtf, idle issue.... - SoutheasternFoxBodies.com Forums This thread Refback May 31st, 2011 09:44 AM
Wtf, idle issue.... - SoutheasternFoxBodies.com Forums This thread Refback May 28th, 2011 02:17 PM
Wtf, idle issue.... - SoutheasternFoxBodies.com Forums This thread Refback May 28th, 2011 10:04 AM
1993 mustang idle's at 200-300rpm! help - Ford Mustang Forums This thread Refback May 11th, 2011 10:36 PM
1993 5.0 Mustang LX 5-speed Manual <acronym title= This thread Refback April 13th, 2011 04:31 PM
Need to tune my Beast! - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback February 15th, 2011 08:50 PM
Need to tune my Beast! - Corral.net : Ford Mustang Forums This thread Refback January 4th, 2011 04:50 PM
Need to tune my Beast! - Corral.net : Ford Mustang Forums This thread Refback January 4th, 2011 01:18 PM
Need to tune my Beast! - Corral.net : Ford Mustang Forums This thread Refback January 4th, 2011 01:17 PM
Idle at 1k rpms - Ford Mustang Forums This thread Refback November 24th, 2010 01:37 AM
intake manifold question - Page 2 - MustangForums.com This thread Refback October 24th, 2010 01:07 AM
To seafoam or not? - Corral Forums This thread Refback January 15th, 2010 06:44 PM
To seafoam or not? - Corral Forums This thread Refback January 15th, 2010 06:12 PM
really need electrical help - MustangForums.com This thread Refback September 12th, 2009 03:28 PM
intake manifold question - Page 2 - MustangForums.com This thread Refback July 8th, 2009 02:19 PM
engine light question - GrandMarq.NET - Panther Headquarters This thread Refback June 19th, 2009 09:16 PM
What are you working on? - Page 180 - GrandMarq.NET - Panther Headquarters This thread Refback June 3rd, 2009 08:37 AM
What are you working on? - Page 180 - GrandMarq.NET - Panther Headquarters This thread Refback June 3rd, 2009 01:27 AM
What are you working on? - Page 180 - GrandMarq.NET - Panther Headquarters This thread Refback June 3rd, 2009 12:41 AM
Idle Surge Mustang 5 0 on Kosmix This thread Refback April 29th, 2009 08:17 AM
Official GTAMC Forums - RPM surging?? This thread Refback March 1st, 2009 12:41 AM
DFWstangs Forums - Need some idle help...!!!!! This thread Refback December 3rd, 2008 06:08 PM
DFWstangs Forums - Need some idle help...!!!!! This thread Refback December 3rd, 2008 05:43 PM
DFWstangs Forums - Need some idle help...!!!!! This thread Refback December 3rd, 2008 03:08 PM
Help! Efi Engine Stalls On Decel. - FFCobra.com - Factory Five Racing Discussion Forum This thread Refback September 29th, 2008 03:15 PM
Official GTAMC Forums - Lets solve this problem.... This thread Refback May 23rd, 2008 10:01 AM
Official GTAMC Forums - Lets solve this problem.... This thread Refback May 23rd, 2008 12:43 AM
Official GTAMC Forums - Lets solve this problem.... This thread Refback May 22nd, 2008 09:53 PM
Official GTAMC Forums - Lets solve this problem.... This thread Refback May 22nd, 2008 09:41 PM
Threads Similar to: 5.0 Base Idle Reset
Cloning A GT 500 From A V6 Base v6hornet 2005 - 2010 17 December 5th, 2007 12:42 PM
Removing Antenna Base? Vision.Pro Visual 4 May 6th, 2007 01:06 PM
shaker base assembly musman Classic Mustangs 0 March 11th, 2007 12:53 PM
Possible to install a 04 Cobra engine in a 99 base? HypeTelecon Modular Mustangs 3 December 19th, 2006 09:11 PM
