1992 LX 5.0
MIG vs. TIG For Subframe Connectors
I was planning to weld my MM full length subframe connectors on tomorrow. I'm reading through the instructions again, and they specifically say to use a MIG welder. I've got a friend in the boilermakers union that is going to do the welding for me, and he has a TIG welder. After speaking with him about it, it sounds like the TIG will work better than the MIG, but I'm curious if anyone could think of a reason why MIG would be better?
¡ʇsnq ɹo uʍop ǝpısdn
TIG welders in general are better for everything, except mass production of parts. with a tig you can control the temp better, but it takes more time... if your friend has it and wants to do it with a TIG let him
Big timin' in a small town
I did it with a MIG really it wont make much of a difference. As long as you get the welded on good they will be fine. But like OMZ said if your friend really wants to weld them on with a TIG let him
the TIGs produce a stronger weld then the MIGs so i think if he wants to do it you have nothing to lose
[rides 1987 ford F-350 XLT Lariat 7.3L idi diesel projects 1979 ford F-350 custom (soon to get 7.3Lidi diesel) 1992 ford mustang notch (just shell soon to get engine and drive train hopefully) |
1992 LX 5.0
Thanks guys, that's exactly what I was thinking.
The MM instructions made me second guess myself, it says a MIG welder must be used. |
a mig weld will be better unless you can turn the car over. you wont be able to control your heat unless you got a slide control. and the HAZ (heat affected zone) is smaller and more focused leading to stress on one point. its possible to make a good weld with either but youll end up with a better weld with a mig.
FX4 Crew
Crew member #3 |
You right but if you have someone that knows how to weld then in the case of frame connectors it really dont make a difference.. It will be plenty strong enough either way. Hell you could even ARC weld them and they will never break as long as you know how to weld. Just have to bust the slag off after ARC welding.
by arc you mean SMAW. there's no reason to bust slag off other than to check weld for pinholes. the problem with doing it with smaw. you put in alot of heat. most people dont know how to weld parts like this. and what rod classification.
FX4 Crew
Crew member #3 |
#9 | |
#10 | |
![]() but the slag does no harm. thats what i thought you were getting at.
FX4 Crew
Crew member #3 |
Threads Similar to: MIG vs. TIG For Subframe Connectors
| Subframe Connectors | gotboost562 | 5.0 Mustangs | 42 | September 13th, 2007 12:17 AM |
| Subframe connectors on my 6 | tjames | V6 Mustangs | 5 | September 11th, 2007 05:15 PM |
| Subframe connectors | Garhfer | 99-04 | 15 | July 10th, 2007 08:41 PM |
| Subframe connectors | Drick | 5.0 Mustangs | 10 | May 9th, 2007 01:18 AM |
| Subframe connectors | shurb125 | 5.0 Mustangs | 5 | February 6th, 2007 10:33 PM |
