Engine Swap Questions
a friend wants to find an early 80's stang with a blown engine and install a 460 big block and a manual tranny, possibly a T5....
the 460 will remain stock except for a manifold and holley carb, and a mallory ignition, headers, flowmaster exhaust, etc.....how easy is this conversion?? would that big block drop in or are there special engine mounts and adapters that have to be installed, and if so, is there a company that specializes in these "kits"?? also, would a T5 be able to handle the 460? it's only good for 400HP, so should he go with a beeifer tranny, or would the T5 handle the added torque and HP?? i suspect that when he finishes the engine it will have about 450 HP with some modifications..it should be a scary ride when he finishes for a small price tag!! any information appreciated, and hopefully someone here has already done this... |
The Razor's Edge
first off a t-5 will be torn to shreads by all that power. you would have to look into aftermarket transmissions.
i think the swap is pretty easy....its been talked about her a few times before. |
Jegs part # 520-6224K that's just for a start
www.hsvracing.com |
Big timin' in a small town
You con buy a swap kit wich gives you motor mounts and the headers neccasary for the swap I belive. And you will need an after market trans the T-5 wont hold together behind a built 460
But why a 460 you can easily build a more than powerfull 351W to put in there without as much hassle
built c-4 will work
www.hsvracing.com |
It would but is it going to be a street car or an all drag car. I wouldnt street a built manual valve body C-4
why not?
make yourself a sleeper!
www.hsvracing.com |
True I guess
id use a C6 behind a 460 even though it would sap a little more power its much more durable than a C4.As for a manual you would need either a G force T-5,TKO 500,TKO 600, or a T56
A C4 won't hold up very long on the street behind a 460. A C6 is a boat anchor. Find a Powerglide or Turbo 400 to use.
LOL @ Darrell. i like your use of the word Boat Anchor.
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
why not get a tubular k member and a arms while your at it
13.64@101mph
very true, but consider thats probably an truck 460..and those from the 80s were rated at highest of 275hp...with carb and intake...290...WHOA..geeze...C6 are rocks, there made to last, but not to last behind pwr..find an old 4spd out of an late 60s mustang that was behind an big block...
if i remember correctly to put the 460 in the fox you have to shave the fire wall
[rides 1987 ford F-350 XLT Lariat 7.3L idi diesel projects 1979 ford F-350 custom (soon to get 7.3Lidi diesel) 1992 ford mustang notch (just shell soon to get engine and drive train hopefully) |
and a new hood!
www.hsvracing.com |
why the engines to tall to?
because eventually i wanna do it to the 92
13.64@101mph
its an big block...also i think they make lowering motor mounts...so you can avoid that
i would rather get the bigger hood
its easyer
and some stiffer springs
www.hsvracing.com |
Threads Similar to: Engine Swap Questions
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
| pi swap questions | LaserRed96GT | Modular Mustangs | 0 | January 10th, 2007 11:51 PM |
| t-5 to c-6 swap questions | 83five0 | 5.0 Mustangs | 5 | December 11th, 2006 06:24 PM |
| 96 To 99 Engine Swap Questions | smenzel444 | 96-98 | 66 | November 9th, 2006 01:49 PM |
