Convertible Window Adjustments
I need some diagrams on window adjustments. Just got a new frame put on the top and the guys won't align the windows to seal to the new frame. Haynes and Chilton has nothing in it about adjusting the windows... Help! I can't drive in the rain!
1993 Mustang LX Vert
I know at the bottom of the 1/4 window rod there is a adjusting nut there to tilt it in or out. Hope that helps
Big timin' in a small town
You have to take off the door panel. There should be stops that you adjust you loosen the nut and move the stop up or down. It stops the window from going up to far.
The front windows I have under control. It's the 1/4 glass I cannot find adjustments on. The front cannot be aligned until the 1/4's are set...
Threads Similar to: Convertible Window Adjustments
| 01 Mustang Convertible rear window... | Josh182 | General Tech | 5 | April 5th, 2008 04:34 PM |
| headlight adjustments | xiiiix | Visual | 4 | June 26th, 2007 08:03 AM |
| hood adjustments | 95kystang | Visual | 1 | June 23rd, 2007 05:16 PM |
| adjustments | DragonFreak | 96-98 | 1 | May 20th, 2007 05:19 PM |
| IAC Adjustments | Garman91 | V6 Mustangs | 9 | May 13th, 2007 05:50 PM |
