Tuning?
Old December 6th, 2007, 01:35 PM   #1
95StangMX's Avatar
95 Mustang GT
Tuning?
TFS-25002 - 255 LPH FUEL PUMP
TFS-21406700 - PUSHRODS
TFS-51400904 - GASKET KIT
TFS-51400801 - VALVE COVERS
TFS-51400004 CO1 - HEADS 185 CNC PORTED
TFS-51500002 - INTAKES
TFS-51400800 - OIL FILLER
TFS-51478520 - TIMING SET
TFS-5150SN95 - INTAKE SPACER
AEI15633 - FUEL PRESSURE GUAGE
AEI13102 - AFPR
SUM29055C-C - 75 MM MASS AIR FOR 30LB AND CAI
BBK1524 - 75 MM THROTTLE BODY
FORD RACING 3:73 RING AND PINIONS
RAT305K - INSTALL KIT FOR RING AND PINION
FMS-M-9593-B302 - 30 LB/HR INJECTORS
HARLAND SHARP ROLLER ROCKERS
BBK EQUAL LENGTH CERAMIC COATED HEADERS
CHP 347 STROKER ROTATING ASSEMBLY
- CAM CUSTOM GRIND
- TRANSMISSION REBUILD KIT FROM DAN AT CLICK CLICK (SILVERFOX) BUILT FOR UP TO 700HP
- 2800 STALL
got everything ordered and in route to my buddy to bring down sunday I am excited as hell to get this thing going...should have everything but the cam and the chip/tune....question is ....is this thing going to run like total shit until i get the tune done? I will have the cam soon and in with the rest of the parts and they are working on the tune but will it even run without?
Old December 6th, 2007, 08:05 PM   #2
Speedstang302's Avatar
13.64@101mph
it wont run like shit with the timing set fine and no leaks or anything...but will run alot better with tune
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old December 6th, 2007, 11:27 PM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Depending on how radical your cam is you may run into the normal . Such as low rpm bucking, the occassional red light stall, high idle, overheating. The T4MO is alittle less forgiving than the fox A9L. You will inevitably have a few bugs to work out, there always is. For the most part she should run ok.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Threads Similar to: Tuning?
Tuning jjperl 96-98 10 September 7th, 2007 02:22 PM
Tuning newstangmike 99-04 0 July 24th, 2007 08:20 PM
tuning?? SEANMD81 2005 - 2010 6 May 28th, 2007 07:20 AM
help with tuning jrhurst Modular Mustangs 9 April 27th, 2007 04:19 PM
Tuning help 94v6blkndred V6 Mustangs 3 March 18th, 2007 11:34 PM
