My Stroker Combo
Old December 6th, 2007, 02:12 PM   #1
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
Smile
My Stroker Combo
Alright, so far this is what ive got down on paper for my big inch stroker/car setup. Thanks to everyone that has helped me to get this far.. i would most certianly be lost without some of you... you know who you are
The combo isnt complete as of yet, so this is just a rough run through, with minor specs. More detailed specs when i make my final decisions.
Shortblock: World Products MOW 9.500" (Zero decked). Forged Diamond pistons (4.125"/10cc dish). Forged Probe lightweight 4340 I-beams (6.200"). Forged 4340 steel crankshaft (4.100"). Clevite bearings, and piston rings. High volume oil pump, Canton windage tray with canton pan. *ARP fasteners will be used everyhwere. Compression (10.55:1). Displacement= 438ci
Heads:TFS-R CNC ported 225cc. (61cc com/chamber.. 2.080 intake/1.600 ex.) Springs, retainers, locks, rockers, valves have all been un-decided. I wont know until i make a final decision on the cam. Im still trying to decide if i want to use these heads, and not the TFS CNC Hi-port race heads.
Induction & Camshaft: Still trying to decide on carbureted or EFI. Most likely EFI, with a TFS-R 351w lower manifold, and Box-R upper. Accufab 90mm TB. CPR Fuel rails, with CPR AFPR. Not 100% sure on injectors, but in the 50lb/hr range. AFM 4in PP (if i can still use it). Camshaft will definetly be a custom grind, solid roller in the .600" range. I'll have final specs when i communicate with the cam provider. The rest of the valvetrain will be matched to the cam and heads.
Fuel System: Sumpted tank, factory located. Aeromotive A1000 pump (submerged). -10 AN feed, -8 AN return.
Poweradders: My current 200hp EFI Dry, single nozzle NX/AFM Nitrous system.
ECU/EMS/Ignition: Anderson Ford PMS Tuner/EEC-IV with S4 InterLog 4.0 data logger and EF-LIPD software for 50+lb/hr injectors. MSD Billet Distro with D7 box.
Exhaust/Headers: Kooks 1" 7/8 LTs. Dr. Gas 3" O/R X-pipe, 3" borla XR-1s.. (already have them on the shelf) Car will have full exhaust, all the way to the factory located tips.
Transmission & Accessories: Not 100% positive YET, but looking at a G-Force T5, with near stock gear ratios. Im still researching clutchs... trying to find something to hold 800lb/ft of torque and still have a decent pedal. Im leaning towards Exedy or Spec. Well see.
Rearend & Suspension: This is where im stuck right now. The suspension will stay stock type, but i havent considered my options yet for replacement parts. I do know that my gearing will be in the 3.73-3.90 range. 5-lug, 33 spline, with modified diff (not sure yet).
Front Suspension: QA1 Tubular Kmember, QA1 tubular control arms. QA1 Adjustable Coil overs, MM caster/camber plates. FR steering rack. SSBC brakes (also on the rear, with 5 lug). No sway bar (atleast not for the track).
Thats just a BASIC run down, when ive made all the decisions, i'll share it all in detail. I know ive missed alot of areas, but this gives you guys a good idea of where im going.. which i hope, is in the right direction. I open to constructive criticism and or other ideas. Thanks for your help everyone!
Anthony
Old December 6th, 2007, 04:34 PM   #2
invisa stang's Avatar
1992 mustang lx notch
invisa stang is on a distinguished road
Send a message via AIM to invisa stang
that compression might be a touch high for the spray but im not 100% sure
[rides
1987 ford F-350 XLT Lariat 7.3L idi diesel
projects
1979 ford F-350 custom (soon to get 7.3Lidi diesel)
1992 ford mustang notch (just shell soon to get engine and drive train hopefully)
Old December 6th, 2007, 05:18 PM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
Don't mill the block all the way down if you don't need to.IMO
Old December 6th, 2007, 05:23 PM   #4
Goblin's Avatar
88mm
10.50:1 compression will work just fine with nitrous. Plenty of race cars today have 14:1 with nitrous.. sometimes higher.
Old December 6th, 2007, 05:25 PM   #5
Goblin's Avatar
88mm
I'd like for it to be zero decked. If i dont have to mill the block, i wont.. but it may need too if the circumstances require it.
Old December 6th, 2007, 05:25 PM   #6
JBIGBOOTSY's Avatar
1990 LX hatch
Goblins right nitrous isn't like boost in reguards to compression.
Old December 6th, 2007, 05:28 PM   #7
Goblin's Avatar
88mm
I need to see if Woody would be interested in doing my machine work.
Old December 6th, 2007, 05:30 PM   #8
JBIGBOOTSY's Avatar
1990 LX hatch
I'd still leave a bit, alot can happen, Ive dropped a cyl. head right on the deck of a friends engine, and gouged it pretty good, needed milling, on the other hand I honnestly haven't had the need to other than that one time, and I haven't heard of too much warping. I just figure murphy's law into everything I do.
Old December 6th, 2007, 05:30 PM   #9
JBIGBOOTSY's Avatar
1990 LX hatch
I think he's a bit far away from you.
Old December 6th, 2007, 05:35 PM   #10
Goblin's Avatar
88mm
LOL.. yeah, ive actually had that happen to me too. I'll see what Woody says.. and what he would do in my situation. But your right, its good to leave some to work with, incase of accidents.
Yeeeaahh, hes a good distance away. Maybe i can find a good deal on frieght.
Old December 6th, 2007, 06:43 PM   #11
woody1 is on a distinguished road
You HAVE to mill the aftermarket block decks, leaving it alone is silly. Needs to be squared.
Old December 6th, 2007, 06:48 PM   #12
Goblin's Avatar
88mm
Well, that solves that. Woody, would you be interested? If so, what would the cost be to fully machine and prep the block to the reciprocating assembly?
Old December 21st, 2007, 05:15 PM   #13
Goblin's Avatar
88mm
Its 99% decided that im switching my plan to a production 351w block, and going with 418ci. Just waiting on my taxes. Woody, im guessing shipping will be about $220ish to 33594? I could be wrong.
Old December 21st, 2007, 07:50 PM   #14
baine21225's Avatar
why the block change?
Old December 21st, 2007, 07:55 PM   #15
1987 ford mustang gt
well see when shes done
im guessing money
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old December 21st, 2007, 07:57 PM   #16
baine21225's Avatar
thats prbly a good guess
Old December 21st, 2007, 08:02 PM   #17
Goblin's Avatar
88mm
Originally Posted by jordan View Post
im guessing money
Indeed. I just dont have the budget for a high dollar block. Plus, the power im looking for is plenty safe with a production block.
Old December 21st, 2007, 08:19 PM   #18
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Just so you are aware, your listed combo is just over 12:1 not 10.55:1.
Old December 21st, 2007, 08:21 PM   #19
if you want it to be lower than 12.1 use a 64 cc comb chamber and it should be around 10.5.1
Old December 23rd, 2007, 08:52 AM   #20
Goblin's Avatar
88mm
Whaaaat? I checked it like 7 times, it said it worked out to 10.55:1.
Threads Similar to: My Stroker Combo
sub and amp combo gkizzle3622 Audio/Video 4 October 29th, 2007 07:47 PM
To Stroker or Not to Stroker? That is the Question! 87StangLX General Tech 13 October 20th, 2007 10:46 AM
What Does My Combo Need? 82GT 5.0 Mustangs 18 November 16th, 2006 07:56 AM
12 Second Combo Tim Stewart 5.0 Mustangs 3 September 21st, 2006 05:34 PM
A Good Combo For A 347 Stroker, 66 Muzzy spang915 Drag 4 September 4th, 2006 09:36 AM
