1988 Ford Mustang GT
8.372@82.8 1/8mile w/1.825 60'
Mini Tubs?
Who has ran them on there car and are they hard to install?I plan on mini tubbing mines because I am working on my suspension and tires etc. So my car can be ready for my 363 or 347 dart setup.(Hopefully with Darrell's old heads on it)
I never thought I would own a mustang!!! |
1990 LX hatch
fixed heads I hope. a mini tub in a fox requires a rear coil over kit, and cutting and welding, in short.
yea I will be getting them fixed.I know how to weld but I dont know what size to get and are you sure about the coil over kit?
http://www.griggsracing.com/ART/mini_tub.jpg never mind it is one hell of a project so I will be calling a local chassis shop
.What else would I need and what sizes you recommend and also what brand mini tubs.Thanks
1990 LX hatch
yea i'm pretty sure, the shocks would be in the way for a mini tub. they mount in the wheel well. Darrell has a mini tub set up, he knows better than me on the topic.
1990 LX hatch
unless you are really pushing the power, ya prolly don't need a set up like that, you can fit a 10.5 slick on a 10" rim with 5.5" back spacing on a stock fox, and that tire size will take you all the way into the 9s
oh ok I should be fine then without mini tubs.Thanks
#8 | |
1989 LX Coupe
Also, you can run 325/60/15's which is plenty of tire for a 347. Like it has been said before, all you need is a BFH..(big fawkin hammer).
I have 11.5 inch tires on a 6 inch backspace with a little fender work. I've seen 1.50 60 foots with no sign of traction loss and I only have about $400 in my suspension total.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
+1. No need for mini-tubs. Go as fast as you can with the smallest tire you can hook with. If your only making 500-600hp... experiment with an 8.50 first.. and if your not getting enough traction, or stability.. then step up to a 10.50. The biggest mistake people make these days is thinking they need a huge tire, to hook very little power (500-1000hp). That may have been true 15 years ago, but today, with advanced tire technology.. you can go fast, on a relatively small tire.
A guy at my school drove a stock 1988 S-10 with a 4 cylinder, and threw 10.5in tires on the back
#12 | |
unny
A mini tub is not necessary. The only reason I did it in my black car was so I could lower the car so it was damn near on the ground. I had my rear axle narrowed about an inch on each end as well. There's no mini tubs in my red car and it 60 foots 1.34 with a 28x10.5 tire.
He also had that little truck running 12s...in the 1/8th. Even brought the time slip to "brag" about it.
my mildly lifted 4x4 tacoma with a 2.7 4 banger ran faster than that with 32x11.50 mud tires
Threads Similar to: Mini Tubs?
| mini v8 engine | Drgnracin72 | The Clubhouse | 25 | May 5th, 2008 04:57 AM |
| Mini-starters | 89StAngerLX | 5.0 Mustangs | 6 | August 30th, 2007 10:23 AM |
| mini cooper s | stanged out | The Clubhouse | 16 | February 16th, 2007 03:39 PM |
| crazy mini | sAJ1420 | Videos | 1 | November 23rd, 2006 07:54 PM |
