Fuel Pumps
Can someone explain the advantage of running 2 fuel pumps.....specifically an upgraded in tank pump an an in line pump?
my understanding is that the fuel pump is variable speed controlled by the computer...in other words, apply more voltage, spins faster, more fuel output. How does the second in line pump work in conjunction with the in tank pump? Thanks in advance! Newt |
The Razor's Edge
umm i don't know just buy a 255 walbro
#4 | |
#5 | |
After i spoke to the procharger rep, I was confused because i have the regulator at the rail. To me, this is a constant pressure pump, and installing a second in line pump will only add more heat to the fuel while possibly increasing the pressure only if the in tank pump supplies an excess volume. I would think the fuel lines need to be upsized as well. |
#6 | |
If your trying to decide on a power adder, and the ZEX and Procharger are your candidates.. i would probably go with the ZEX system. Cheaper, and can provide the same gains the supercharger will, and is much easier to install and tune. Is the ZEX system wet, or dry?
#7 | |
attached is a pict of all the components we will be installing over the winter. |
#8 | |
#9 | |
let me try the pict again Last edited by Newtgadget; December 17th, 2007 at 10:43 PM. |
Looks like a good set of parts. How much nitrous do you "want" to use? How much additional HP are you shooting for? I just want to give you a heads up... single nozzle wet, and wet spraybar/plate systems that mount behind the throttle body, or spray in front of the throttle body are prone to backfires and nitrous explosions when used with high levels of nitrous.
#11 | |
Since this is a stock block, I am shooting for around 500hp. Stroker I've been told is about 350-365 hp, twisted wedge heads with the correct bolt ons baybe another 50, so i'm thinking about 100 shot. |
#12 | |
#13 | |
The reason i am asking the fuel questions for the procharger is because I am building another motor for my project car which I intend on running supercharged. I was possibly thinking about putting it on my wifes car to work out the problems before I installed it on my high dollar motor to work out any bugs. |
Threads Similar to: Fuel Pumps
| Fuel Pumps | MustangMatt96GT | Modular Mustangs | 2 | May 14th, 2007 12:54 PM |
| 4.6 fuel pumps and tanks which way to go? | WAR-PARTY | 99-04 | 11 | January 1st, 2007 01:40 PM |
| fuel pumps | CyberPrey | V6 Mustangs | 1 | November 28th, 2006 06:26 PM |
| Fuel Injector sizes without regulators or fuel pumps | streetstang06 | 96-98 | 15 | February 26th, 2006 10:02 PM |
| Fuel pumps | Bill | 5.0 Mustangs | 5 | December 18th, 2005 10:21 PM |
