need help , MAP on MAF converted 86 gt
Old August 31st, 2006, 12:48 AM   #1
chadjones99's Avatar
chadjones99 is on a distinguished road
I need help too please, i have a 86 GT that has been MAF converted. and the car has been down for a year, and i just got the engine back in it and running..sound great, but i have not drove it yet, still doing odd's and ends to it. here is the question i see what looks like a MAP sensor, and it looks like it is hooked up, but there is no vacuum line going to it. I dont remember if i took this off or not ? the car starts good. but i dont know if it was taken off for the MAF convertion ? or if i did it. should i hook this up to a vacuum line or not ? anyone know if there's is hooked up ?
thanks
chad
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion
Threads Similar to: need help , MAP on MAF converted 86 gt
Adding check engine light to a mass air converted car?????? black88 Audio/Video 1 February 1st, 2008 05:54 PM
95 converted to carb need help with irratic RPM while drivin Stang955.0 5.0 Mustangs 5 April 29th, 2007 11:34 PM
I converted !! nohobandit 2005 - 2010 39 January 25th, 2007 09:56 AM
