Engine Shaking
So today i drove for about five minutes. Then i turned it off and got out, for a minute. I came back and started my car, and the whole entire car is shaking. I've had the car for two months, and besides this the car has been running perfect. Anyone ideas on what is wrong?
95 Mustang GTS, 5 Speed, MAC O/R H Pipe, MAC Catback, BBK CAI, Eibach Lowering Springs, Steeda Tri-Ax, Black Bullit 17x9 with 255/40/17 BFG t/a kdws. |
1965 Mustang Fastback
you have a really big camshaft
I'm a good boy now. [COLOR=red][B]slow car club - crew member 7 of 9 [COLOR=White]Mood: Cool :cool: [/COLOR][/B] [/COLOR] |
95 opalfrost gt
Check the harmonic balancer and your motor mounts. First thing that comes to mind.
13.64@101mph
could have dropped an cylinder by an bad spark plug...that causes an shake..also you will notice it a little more sluggish...along with you can hear it running different...could be that..could be a million different things
Its hard to tell between a non firing cylinder and a bad harmonic balancer, well it was hard for me. Not a perfect solution but you could attach a timing light to each individual wire and look for the flash for a spark issue, if a plug is bad and not firing, the light should not flash because there will be no current traveling through the wire. For the harmonic balancer, look at it and make sure it is even, the rubber insulator is even and in place between the outer and inner ring, and the outer ring is not loose or cocked funny. PS.. If it is the harmonic balancer, do not run it until you replace it!
I'm going to replace the harmonic balancer in a couple of days. I'll let you guys know what happens.
I hope that is it! Mine required a 15/16 6 point socket and an extremely large breaker bar.
13.64@101mph
well with the radiator out its alot easier to remove...but an impact wrech is you're best too...
Ok, well I just picked up the balancer tonight. But I won't be able to put it in until the weekend, I'll let you know how it goes. What parts will I need? Will I need a puller?
You can rent one form your local auto zone..........damn I sound like an advertisement.
Or buy your own HB puller, they are about $15. A large gear puller should work. The only thing extra I used was red threadlocker on the crank bolt because the previous person used it as well. Not sure if it is required though. Some people suggest replacing the crank bolt with a new one, I didn't. That would suck if your old one broke off.
#12 | |
Hey Opal I just want to make sure you understand its all in fun and you are not one of those people?... If you are now I know. If you are not then oh well!!! ![]()
The Razor's Edge
could be as simple as a spark plug....
#14 | ||
13.64@101mph
I had a simular prob, check carefully all the clutch fan items. mine was cracked and was throwing everything off balance. Also I have had a cracked flex plate on an auto that was cracked and would throw everything out of line
just some extra thoughts for ya |
I changed the balancer and the problem was fixed. I was also able to replace it without having to move the radiator. Thanks for the help everyone!
Threads Similar to: Engine Shaking
| my car is shaking? | villatic | V6 Mustangs | 44 | June 22nd, 2007 09:09 PM |
| Shaking at the wheel | Wilson00V6 | V6 Mustangs | 3 | December 10th, 2006 08:47 AM |
| Grinding Or Shaking Sound | Bill | 5.0 Mustangs | 20 | November 3rd, 2006 11:59 AM |
| Car shaking below 1500 rpm | 90Stang | 5.0 Mustangs | 5 | August 25th, 2006 01:40 PM |
| Shaking Problems | garyvang | 5.0 Mustangs | 3 | May 10th, 2006 07:04 PM |
