Car Stalls
Old December 12th, 2007, 02:49 PM   #1
ridebmxfbm's Avatar
1988 Mustang GT Vert
ridebmxfbm is on a distinguished road
Car Stalls
I have an 88 Mustang Gt Vert, It's an AOD. And I was driving to school and when I was hitting bumps on the way to the car that car would like jump out of gear even if I was pressing the gas the car's rpm would go down under a 1,000 after hitting bumps. Then I get to school and turn and the car just stalls, I drive again to park and it kept stalling everytime I would put it in reverse or would try and turn the wheel. Could it be the alternator or anything else? Help needed
Old December 12th, 2007, 05:31 PM   #2
SPATIK is on a distinguished road
where does it usually idle at after warming up?
Old December 12th, 2007, 05:33 PM   #3
loose conection maybe
could be a loose connection somewhere or might just need the idle set up a little bit? maybe dodge the bumps.
Old December 12th, 2007, 06:46 PM   #4
The Razor's Edge
White Thunder's Avatar
a easy way to check for the alternator is to start your car then un hook your battery....if the car still runs then your alternator should be fine. could be alot of things doing this to your car......could be something in the mass air shorting out....it really could be alot of shit
founder of the FTN Club
Old December 12th, 2007, 06:49 PM   #5
ridebmxfbm's Avatar
I tested the alternator and its fine, the voltage is actually alot higher when the battery is disconnected, and the idle is fine. Mass air is out of the question, its speed density. This has been going on since it started to vibrate, so I gave it a complete tune up. And it still vibrates at idle and runs perfect at normal speed, when it gets to idle the voltage goes down alot..
Old December 12th, 2007, 06:52 PM   #6
The Razor's Edge
how many miles on it.....could be something in the fuel system sounds like it could be starving for fuel at idel....you should talk a lil more.....maybe the injectors are cloged even the fuel filter.....
Old December 12th, 2007, 06:57 PM   #7
ridebmxfbm's Avatar
changed fuel filter, 20,000 on motor I used fuel injector cleaner and it made a little difference, but i still dont know what it is
Old December 12th, 2007, 07:01 PM   #8
The Razor's Edge
spark plugs and wires......or fuel....sounds like something isn't firing or getting fuel....im sure someone else will chime in with there thoughts
Old December 12th, 2007, 07:07 PM   #9
ridebmxfbm's Avatar
spark plugs, spark plug wires, distributor cap, rotor, everything is all new just changed.. idk what it could be
Old December 12th, 2007, 07:08 PM   #10
invisa stang's Avatar
1992 mustang lx notch
invisa stang is on a distinguished road
Send a message via AIM to invisa stang
when you rev it up past 2000 or 3000 rpm does it skip?
[rides
1987 ford F-350 XLT Lariat 7.3L idi diesel
projects
1979 ford F-350 custom (soon to get 7.3Lidi diesel)
1992 ford mustang notch (just shell soon to get engine and drive train hopefully)
Old December 12th, 2007, 07:28 PM   #11
ridebmxfbm's Avatar
no not at all, runs good only at idle does the voltage go down, and the car stalls at times when turning the wheel, also the bumps are big issue it only happens sometimes not always...
Old December 12th, 2007, 07:29 PM   #12
The Razor's Edge
you don;t have UD pulleys do you..sounds like the alt to me now....
Old December 12th, 2007, 07:33 PM   #13
ridebmxfbm's Avatar
no no UDP, but when I unhook the battery, the voltage level goes up at idle... instead of going down or dieing
Old December 12th, 2007, 07:34 PM   #14
The Razor's Edge
something is pulling power away.....there is a thing as overcharging to...
Old December 12th, 2007, 07:37 PM   #15
ridebmxfbm's Avatar
no the voltage never goes higher then the middle at WOT
Old December 12th, 2007, 07:43 PM   #16
there could be a bad connection going from the altinator
[rides
projects
Old December 12th, 2007, 07:46 PM   #17
The Razor's Edge
its something random...do you know how hard it is just to guess at whats wrong....
Old December 12th, 2007, 07:47 PM   #18
id have to be there when it does it to figure it out
[rides
projects
Old December 12th, 2007, 08:04 PM   #19
ridebmxfbm's Avatar
damn it sucks... thanks for trying though
Old December 12th, 2007, 08:12 PM   #20
has it done it latly?
[rides
projects
Threads Similar to: Car Stalls
Help Car Randomly Stalls? chaosstangman 5.0 Mustangs 4 November 17th, 2007 12:12 PM
Car almost stalls ryanhewett466 5.0 Mustangs 7 November 8th, 2007 09:12 PM
car stalls when hot tims3.8stang V6 Mustangs 5 September 17th, 2007 12:45 AM
Stalls Out thagreen1 94-95 12 November 7th, 2006 12:26 AM
Car Stalls stangliter04 General Tech 7 July 17th, 2006 11:02 PM
