2003 Mustang GT
Crank Shaft Pulley! Pls Help!
i been on this one pulley all day, any tips/advice for braken it free??? i got a airgun on it and it hasnt budged thanks in advance for help!
You mean the 4 bolts that hold the pulley to the dampener?
PB blaster and a Ingersoll Rand 1000 ftlb impact should get the job done. If not you can always pull the dampener and get a new one...lol
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1990 LX hatch
Wd40 aint got s*&t on PB blaster.
¡ʇsnq ɹo uʍop ǝpısdn
both products are good i use WD for bolts PB didn't work to well for me... and its not to... helpful when in a small spot with bad ventilation if you know what i mean...
try putting the belt back on to stop the spinning of the pulley its self? make sure your gun is up to the right PSI and if that doesn't work get a really big wrench and give it a good sudden jerk...
1987 Mustang GT
gotta get jig a loo
Threads Similar to: Crank Shaft Pulley! Pls Help!
| crank pulley | mikedoogen | Modular Mustangs | 3 | June 20th, 2007 01:22 AM |
| crank pulley help | mikedoogen | 2005 - 2010 | 3 | June 19th, 2007 01:17 PM |
| Crank pulley bolt? | 88gtstang | 5.0 Mustangs | 3 | March 9th, 2007 10:23 PM |
| HELP!! how do i remove the crank shaft pulley?? | Onemanzu | V6 Mustangs | 12 | December 30th, 2006 01:47 PM |
| Crank Pulley diameter | 97TunedMustang | V6 Mustangs | 2 | February 7th, 2006 07:26 PM |
