Smog & A/C Delete - Page 3
LinkBack (4) Thread Tools
Old November 8th, 2011, 01:40 PM   #41
PONYMAN's Avatar
PONYMAN is on a distinguished road
Send a message via Yahoo to PONYMAN
Originally Posted by whitefox89 View Post
Ok, let me start by saying this thread is going out for all of the people that ask about eliminater pulleys for smog and a/c. You can do that but if you're on a budget and need to save as much $ as possible, this may be a solution to your problem.
I am not sure if there has been a thorough run through on how to do this but i will try and make it short and to the point...
As you can see there are 4 diagrams, but i know most people that want to get rid of smog also want to get rid of a/c too. So, it would do you no good to get rid of power steering and smog just to keep a/c.
The last diagram will be how the belt will end up being ran, you will need to take a tape measure to get a good judgement on the length of belt you need.
Ok, so you will unbolt the tensioner pulley from the alternater bracket by loosening the bolt on the rear side of the tensioner with a wrench or impack if need be.
You will have a tab on the back of the tensioner like on the farthest pictured.
You will need to grind that off completly to get a flat surface like tensioner #2.
Here is an example of a finished product. The tab was ground off so that you could pull the tensioner tight to get a hold on the shorter belt. Proceed to tighten the bolt on the rear of the tensioner back into place.
I decided to grind some of the tensioner housing away so i would have no problems of clearance. You could also run a little longer belt than what i have ran. (my setup has an underdrive crank pulley so i can not be certain my size belt will fit all setups)
If you decide to grind some of the tensioner housing away make sure to remember the bolt on the front of the pulley is reverse threaded. Righty Loosey, Lefty Tighty.
-Well this concludes removal of the smog & a/c pulley to run a smaller belt. I hope i covered all the details and could help. If somebody would like to chime in on the actual removal of the smog pump and pump lines that would be appreciated.
Hey man , I know this is an old post ,but thanks for the diagrams & info.
My Stang is now back on the road & I saved a few dollars by using your diagrams .
Have you driven a Ford lately ?
Old December 29th, 2011, 10:28 PM   #42
1FAST6's Avatar
1989 LX hatch
15 and change
1FAST6 is on a distinguished road
anyone have a part number for the waterpump shown in the pic? It has to spin opposite from the factory one right?
1987 Buick Grand National
1989 Mustang LX 5.0
Both BLACK
Old December 31st, 2011, 01:14 AM   #43
FastStang91Lx's Avatar
1991 Mustang LX 5.0
The waterpump is a reverse rotation water pump. SAME as STOCK. That IS the one shown in the pic.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/46467-smog-c-delete.html
Chris91LX's...er....1991 LX - Page 22 - CMC Forums This thread Refback August 5th, 2010 03:15 PM
Chris91LX's...er....1991 LX - Page 22 - CMC Forums This thread Refback August 5th, 2010 02:10 PM
Chris91LX's...er....1991 LX - Page 22 - CMC Forums This thread Refback August 5th, 2010 12:25 PM
1989 Mustang GT emissions removal - Ford Mustang Forums This thread Pingback June 4th, 2008 07:01 PM
Threads Similar to: Smog & A/C Delete
Smog Pump Delete? 5-0stank 5.0 Mustangs 20 July 14th, 2008 04:24 PM
Smog Delete? 95blackbeauty 94-95 8 December 20th, 2007 02:44 AM
SMog pump delete kit javier351lx 5.0 Mustangs 9 August 20th, 2007 02:24 PM
Smog Pump Delete mdvaldosta 5.0 Mustangs 2 September 11th, 2006 11:13 AM
Smog Pump Delete? 00SoSlow V6 Mustangs 18 August 16th, 2006 12:04 AM
