Smog & A/C Delete
LinkBack (4) Thread Tools
Old December 14th, 2007, 03:10 AM   4 links from elsewhere to this Post. Click to view. #1
whitefox89's Avatar
whitefox89 is on a distinguished road
Smog & A/C Delete
Ok, let me start by saying this thread is going out for all of the people that ask about eliminater pulleys for smog and a/c. You can do that but if you're on a budget and need to save as much $ as possible, this may be a solution to your problem.
I am not sure if there has been a thorough run through on how to do this but i will try and make it short and to the point...
As you can see there are 4 diagrams, but i know most people that want to get rid of smog also want to get rid of a/c too. So, it would do you no good to get rid of power steering and smog just to keep a/c.
The last diagram will be how the belt will end up being ran, you will need to take a tape measure to get a good judgement on the length of belt you need.
Ok, so you will unbolt the tensioner pulley from the alternater bracket by loosening the bolt on the rear side of the tensioner with a wrench or impack if need be.
You will have a tab on the back of the tensioner like on the farthest pictured.
You will need to grind that off completly to get a flat surface like tensioner #2.
Here is an example of a finished product. The tab was ground off so that you could pull the tensioner tight to get a hold on the shorter belt. Proceed to tighten the bolt on the rear of the tensioner back into place.
I decided to grind some of the tensioner housing away so i would have no problems of clearance. You could also run a little longer belt than what i have ran. (my setup has an underdrive crank pulley so i can not be certain my size belt will fit all setups)
If you decide to grind some of the tensioner housing away make sure to remember the bolt on the front of the pulley is reverse threaded. Righty Loosey, Lefty Tighty.
-Well this concludes removal of the smog & a/c pulley to run a smaller belt. I hope i covered all the details and could help. If somebody would like to chime in on the actual removal of the smog pump and pump lines that would be appreciated.
Old December 14th, 2007, 03:17 AM   #2
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Sticky this
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old December 14th, 2007, 04:59 PM   #3
Drick's Avatar
Bump
FX4 Crew
Crew member #1
Old December 14th, 2007, 05:50 PM   #4
whitefox89's Avatar
Old December 15th, 2007, 04:28 PM   #5
whitefox89's Avatar
Originally Posted by 8t6gt View Post
Sticky this
Old December 17th, 2007, 04:05 AM   #6
whitefox89's Avatar
Old December 17th, 2007, 06:31 AM   #7
1990 GT
bigdawg is on a distinguished road
good write up.
Old December 17th, 2007, 07:09 AM   #8
whitefox89's Avatar
thank you, if anybody has something to add as far as smog pump/lines removal id appreciate it.
Old December 17th, 2007, 02:28 PM   #9
1990 Mustang GT Hatchback
JcSurge311 is on a distinguished road
Send a message via AIM to JcSurge311 Send a message via Yahoo to JcSurge311
well this was in my case but the 84.5" belt was way to big. the 78" belt i got worked perfect for the a/c and crank and water pump and alternator and power steering. just
there can only be one....
Old December 17th, 2007, 06:02 PM   #10
whitefox89's Avatar
I found that diagram on google. i would recommend just to measure what you need instead of going off somebody elses thought. im not sure if they are correct but it was good way for me to show a diagram of how to run the belt for a/c and smog removal.
Old December 18th, 2007, 01:03 PM   #11
EscortSportage's Avatar
1989 Mustang GT 5.0
U R THE MAN! THIS IS what ive been talking about for the longest instead of buyin those elimanator brackets for like 80 y dont u run a smaller belt! amazing!
Old December 18th, 2007, 01:12 PM   #12
baine21225's Avatar
Sticky This Fo Sho
Old December 19th, 2007, 12:35 AM   #13
whitefox89's Avatar
Thanks, thats what i made it for. I know alot of people have asked.
Originally Posted by baine21225 View Post
Sticky This Fo Sho
+1
Old December 19th, 2007, 12:51 AM   #14
TT86 is on a distinguished road
Great little write up you gave here, I'm sure it will give lots of great ideas to people. I'll toss in a little more extreme routing too. Recently I found my self in need of running only an Alt and water pump, but did not want to buy a new opposite rotation water pump for my car, so I relocated my tensioner on a piece of plate aluminum, with a 45.5" belt... and well here it is... the way the tensioner is positioned, it actually tightens the belt under acceleration......purposely
69 convertible:
302/ DART heads/Z303 cam/Vic Jr./ 650 DP
Tremec w/ 4:10s
86 hatch:
302/ Edel Al. heads/ F303 cam/
twin Garret T3 turbos
10 psi intercooled
52# injectors
MegaSquirt II EMS
http://www.youtube.com/watch?v=_urWMgS_IRQ
Old December 19th, 2007, 12:56 AM   #15
whitefox89's Avatar
Nicely done
Old December 19th, 2007, 02:14 AM   #16
Drick's Avatar
Itsnt it bad if it tightens the belt tho. To much resistance
Im gonna use this when I go home too
I still want my A/C but smog is going to GTFO of my car
FX4 Crew
Crew member #1
Old December 19th, 2007, 02:24 AM   #17
whitefox89's Avatar
Id worry about the belt sliding since there are no "sidewalls" i guess is what they're called on the pulley. but if it works i guess it works.
Old December 19th, 2007, 02:33 AM   #18
ryans88gt's Avatar
.[/quote]
2 things I can add. You can see in this picture how you could also run it without the Power steering, just the water pump and alt. You do need a standard size crank pulley however to get enough belt on the water pump if you don't run a PS pump.
the second thing is, you can get a tensioner that goes the opposite direction of the stock one so that it pulls the belt ups. I would give you the part number, but my cars in storage for the winter.
Nice work!
Old December 19th, 2007, 02:39 AM   #19
ryans88gt's Avatar
March sells the same thing for $50, however they recommend a slightly different belt routing.
Smog & A/C Delete-pulleys.jpg
Old December 19th, 2007, 02:41 AM   #20
whitefox89's Avatar
that march one looks nice. someday i will upgrade all my pulleys and what not to look good. but for now. functional is what im lookin at. lol
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/46467-smog-c-delete.html
Chris91LX's...er....1991 LX - Page 22 - CMC Forums This thread Refback August 5th, 2010 03:15 PM
Chris91LX's...er....1991 LX - Page 22 - CMC Forums This thread Refback August 5th, 2010 02:10 PM
Chris91LX's...er....1991 LX - Page 22 - CMC Forums This thread Refback August 5th, 2010 12:25 PM
1989 Mustang GT emissions removal - Ford Mustang Forums This thread Pingback June 4th, 2008 07:01 PM
Threads Similar to: Smog & A/C Delete
Smog Pump Delete? 5-0stank 5.0 Mustangs 20 July 14th, 2008 04:24 PM
Smog Delete? 95blackbeauty 94-95 8 December 20th, 2007 02:44 AM
SMog pump delete kit javier351lx 5.0 Mustangs 9 August 20th, 2007 02:24 PM
Smog Pump Delete mdvaldosta 5.0 Mustangs 2 September 11th, 2006 11:13 AM
Smog Pump Delete? 00SoSlow V6 Mustangs 18 August 16th, 2006 12:04 AM
