Discussing Woody.. HELP!! in the 5.0 Mustangs Forum. I was going through your website.. and looking at all the goodies you have to ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Editor
Secret In The Works
Woody.. HELP!!Ant
Definition of Fast? ![]() I'd say thats good enough. ![]() NMRA Outlaw 10.5 Season Opener 2008 Photo courtesy of - Yours Truly |
1990 Mustang LX
9.36@143 mph
The title "woody help" really thru me for a loop.......
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
Editor
Secret In The Works
HAHAHAHA Thas fuunny
what are the goals, what do you ultimately want? Thats the first question. Cast steel will go 550-575 a bit higher but I cant tell guys that, steel will outlive any productin block as the main caps are the first problem with a production block around 650-700, they tend to start walking and chattering.
Editor
Secret In The Works
Realistically. I want ATLEAST, bare minimum 550hp. I really like the idea of 600+.. but im trying to stick with pump gas. I might, possibly be using some nitrous, im starting to think i might not with this motor, and try to be fast without it. So, between 550-600.. solid roller, on pump gas.
1990 Mustang LX Turbo
8.67@165.91 mph
not on a stock block i hope
Wiring Diagrams, TSB's, OBD Service Codes and Engine Diagrams Available. PM For Info Myspace Small Block Posse |
Editor
Secret In The Works
Yes, with a factory production block.
A well prepped 351w early block will hold 600 hp for a long time. As high as 700-800 hp is a pretty good guestimate of the power potential of a stock block before it cracks. A man-o-war block is definitely not needed for 600 hp.
89 LX 515 hp 497 ftlbs 88 GT 11.4 @ 118
#10 | |
Editor
Secret In The Works
IN the last 15 years, I have not had any cracking issues with the production windsors, its the cap walk that takes out the main bearings, almost every single time. 500-600 on pump gas will go 10's easy, if not take up knitting
#12 | |
Editor
Secret In The Works
Ant
Hey woody, have you ever tried any of the aftermarket main caps or girdles. How much help do you think you get there? My dirt track engine builder swears by aluminum main cap girdles, says they soak up harmonics that cause cap walk.
Run the 408, I like those best, the only people that call for a 427 are the AC cobra kit car guys which is silly, but oh well. As for main caps, ya we used the steel ones on 69-70 blocks withut the necked down mains BUT its not a cheap operation at all. Figure 700-800 dollars for good caps installed, PLUS the regular 500+ in machine work makes for an expensive stock block.
Editor
Secret In The Works
Sweet, i might actually have a completed shortblock by the time my taxes come back. Instead of having a bunch of unassembled parts. Im excited.
Editor
Secret In The Works
Im still curious though, what valve covers were on that motor.
1989 LX Coupe
They say Ford Strokers on them.
I believe they make them.
![]() 7.87 @ 93 mph
Editor
Secret In The Works
If he does, sweet. I want a set.
#19 | |
you know as well as I do 1500 in a stock block vs a dart etc.. IF you are needing a block to sustain 700+ dont spend 1500 on a stock block. Sure you can run a 2.750 with the stock caps, get the bearing spacers, line hone and voila. Hell you cant get a dart block with a 3 inch main. No the valve covers were made for me with my stickers on them, just an experimental thing
