#21 | |
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#22 |
48.47@ 12.58
since when is a stock 5.0L a performance engine?
![]() if you plan on using plat plugs for longer use.. go for it.. just don't toss a blower on your car or put heavy bolt on's on her.
#24 |
By your numbers the resistance is 10 times more (the all important exponent).
Also this is at 20 degrees C, your combustion chamber is more like 1000 degrees C, so expect that difference to be more like 100 to 1000 times more resistance. Temperature and resistance are proportional.
#25 |
so why dont we just come to a conclusion... what MATERIAL spark plugs? not what brand.
Are those non-adjustable iridium ones pretty good? the little 4 prong ones, i heard they spark pretty hot (good for stock performance)
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
#26 |
autolite, AR25. $1.50 each and works as well as any other. no need to bust open the piggy bank in this area yall. if there is a difference from any plug to another (within the same heat range) it is a negligible difference and not worth the difference in price.
buying "unobtainium 15 electrode spark plugs with ESP technology" is akin to buying a bassani x-pipe over a brand that cost half as much. how much difference do you think it could really make? is it worth the $200-300 price difference? IMO hell no! spend your money buying better parts where it actually makes a difference. my2cents anyway |
#27 |
what if you have a turbo??
Fastfordsoftexascc.com |
#28 |
I use NGK V-Power. Never had a problem.
#29 |
Autolite, they are the same brand as motorcraft. They are cheap and have copper electrodes. They are available in almost every heat range. They are what most performance FORD engines use.
#30 |
1988 Mustang LX Turbo
there all pretty much the same, i run motorcraft plugs in both of my cars with MSD kits
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
#31 | |
#32 | |
#33 |
Its a discussion, not a street fight. Its cool dude.
#34 | |
#35 | |
a speark plug is a spark plug but like darrel said, " autolite, NGK, champion" those have been around forever and they dont try to sell bull s***, you cant go wrong with them and there isnt a spark plug out there that improves throttle response |
#36 |
and the ones with multiple prongs are a joke to!
its still the same amount of spark jumping the airgap and the electrons are always going to jump the prong with the less resistance! so there for your paying $10 more for 3 extra prongs that you arent going to use its all b.s. |
#37 | |
#38 | |
hahaha i sleep in science class to!
Threads Similar to: Spark Plugs
| Spark Plugs | 89LX347 | 5.0 Mustangs | 1 | October 9th, 2007 01:10 AM |
| spark plugs. | Ware | V6 Mustangs | 12 | October 3rd, 2007 09:37 AM |
| spark plugs | ROUSHME661 | V6 Mustangs | 11 | July 14th, 2007 10:15 PM |
| Can Someone (Pic Of Spark Plugs) | Luvdmustang | 96-98 | 4 | January 26th, 2007 01:12 AM |
| Spark Plugs | Drgnracin72 | 99-04 | 17 | November 13th, 2006 02:10 PM |
