Vibrations! - Page 2
Old December 16th, 2007, 06:31 PM   #21
sneezingfox's Avatar
sneezingfox is on a distinguished road
Alright. Just swapped the shaft 180 deg. Going for a test drive. Post in a few mins..
Old December 16th, 2007, 06:47 PM   #22
Hell yeah! No more vibrations. That really slowed the car down. I can feel a little vibration at low speed/rpm and heavy on the gas, but very little, if any, hard to tell. Man, I seriously need some stopping power...
Old December 16th, 2007, 06:48 PM   #23
Oh, yeah. Thanks, Darrel. You saved me much labor hours, not that putting in a clutch and flywheel wasn't fun, but don't want to take it all apart again if I don't have to...
Old December 16th, 2007, 08:49 PM   #24
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No problem. Glad to hear it worked. I've ran into damn near every problem possible on these cars over the past 15 years. You always have to try the simple free things first.
Old December 17th, 2007, 02:28 PM   #25
Dammit all the hell! Got on the freeway today and hit 85mph... guess what?! Vibrations are back! Getting pissed. Any time I mess with the driveshaft, the vibrations change. It's not bad as it used to be, but it is still there...
Old December 17th, 2007, 11:38 PM   #26
So no one has installed a clutch and got vibrations when they were done?
Old December 18th, 2007, 12:37 AM   #27
ryans88gt's Avatar
Go get your wheels balanced and then come talk to us...
Old December 25th, 2007, 08:15 PM   #28
Wheels get out of balance just like that? I took the shaft into a driveshaft shop. They said it still had the factory balance on it, but was still a little off. So, he fixed it. Got it back on the car, and IT'S STILL THERE! Anytyhing else to look for before I pull the tranny and clutch out?
Old December 25th, 2007, 08:39 PM   #29
e3sean's Avatar
1988 lx
9.68@142
If I put in the clutch, the vibes go away. . HELP!
so if your going 85 and u push the clutch in rpm goes down and vibration is gone... well the shaft is still moving at the same speed so its not that... my guess would be the clutch is out of balence take the flywheel and clutch off bring that to him and see if its in balence..and it wouldnt be the wheels ither cause when the clutch goes in vibrations go away..
Old December 25th, 2007, 11:20 PM   #30
Alright, guess I'm pulling out driveshaft, tranny, bellhousing, clutch, and flywheel tomorrow...
Old December 25th, 2007, 11:53 PM   #31
ujslost's Avatar
i have the same problem as you let me know what you find
mine would vibrate with cluch in also, except in 4th gear for some reason. took out DS raised rpms still vibrated, took trans out, and did it again, still vibrations. taking the clutch shit out and changing my flywheel now
Old December 26th, 2007, 01:07 AM   #32
e3sean's Avatar
1988 lx
9.68@142
put your car in neutral and keep the rpm stedy at 3k 4k exc and see if it does it.. if it doesnt then it cant be the clutch or flywheel but if it does then its pretty safe to say its not the drive shaft or wheels.. do u have the orignal damper on it?
not sure if this would cause that but could you maybe have a loose main cap?
i am gonna say it has something to do with the clutch/flywheel cause thats all u changed..
Old April 7th, 2008, 08:05 PM   #33
Standardrift is on a distinguished road
i know this is a very late reply, just wondering if you fixed the vibration; if not, its your drive line angles that need to be fixed
Old April 7th, 2008, 08:17 PM   #34
ujslost's Avatar
oh well, i found my problem was a bent drive shaft
Old April 7th, 2008, 09:51 PM   #35
turbodgumby's Avatar
95 Lightning-Twin Turbo
10.66@126
turbodgumby is on a distinguished road
do you have a buddy that you could try swapping driveshafts?? If the 180 turn doesnt work.
'95 Lightning-842rwhp/936rwtrq pumpgas
Twin T-70 Turbos
393w stroker(stock block)
TFS CNC heads
Cam Motion Custom Grind Hyd Roller cam
BBRC EFI Spyder intake
FAST
Stock 185,000 trans(PI3000 converter,PUNISHER VB)
Drag Radials always
Old April 7th, 2008, 10:04 PM   #36
91cobra5.0's Avatar
98 Cobra
just throwing this out there but check you wheels to see if they are missing wieghts, if they are out of balace i know it will cause vibration, maybe if its not off too much then maybe thats why it doesnt start till your going so fast??
just an idea
Threads Similar to: Vibrations!
Really bad vibrations mustangchris 5.0 Mustangs 5 October 7th, 2007 06:20 PM
vibrations 89beastin 5.0 Mustangs 8 April 16th, 2007 01:11 AM
My whole car started shaking... Really bad vibrations ??? 1911A1 5.0 Mustangs 8 February 28th, 2007 09:13 AM
