Smog Pump
Old September 3rd, 2006, 09:18 PM   #1
jcc1991 is on a distinguished road
Smog Pump
How do I remove the smog pump on my 95 mustang GT 5.0? And what performance issues will I have if I do that?
Old September 4th, 2006, 03:30 AM   #2
dcraig8 is on a distinguished road
first of all, there are i believe two bolts that hold the smog pump on. remove those, disconnect and cap off the two vacuum lines that go to the plumbing. then remove the plumbing. one tube goes from the pump to your manifold. take that one off and put a metal cap on the bung where it went to the manifold. the other tube goes from the pump to your midpipe. remove that one and again put a cap on the bung at the midpipe. there will be brackets along the way also. remove them(i believe they will come off with the plumbing.) you will not suffer any performance losses at all or any gas mileage. are you going to put a smog pump delete pulley on also?
Old September 4th, 2006, 09:42 AM   #3
I thought about that, but I was told that they can go bad and its easier to just get a belt for a mustang without A/C and that would work better. What do you think?
Old September 4th, 2006, 12:51 PM   #4
i havent had any problems at all with mine. its been 5 years since ive done the delete. but getting a belt for a mustang without a/c would work too.
Threads Similar to: Smog Pump
smog pump skid6 5.0 Mustangs 4 October 9th, 2007 09:06 PM
smog pump cali 5.0 Modular Mustangs 0 April 21st, 2007 01:08 AM
smog pump help stangzilla 331 5.0 Mustangs 2 March 11th, 2007 10:04 PM
smog pump cali 5.0 5.0 Mustangs 3 July 24th, 2006 02:03 PM
