1988 Mustang Electrical Issue
Old December 18th, 2007, 03:55 PM   #1
kuskye25's Avatar
kuskye25 is on a distinguished road
HI,
This morning when i started my car all is well accept i have no heater fan, rear defrost, or turn signals. So far everthing else is working and the car runs fine... Last night everything was working perfectly when I shut it off. All fuses in the interior check out.
Just wondering if anyone has any ideas, or if it is a fusible link maybe somebody can help me in the direction of which one...
Thanks
'88 Mustang GT, Long Tube Headers, Off Road H-pipe, Flowmasters w/turn downs, K&N, Under Drive Pullies, Smog delete/Ac eliminator/72" belt, Subframe connectors, 3.73 Gears
'93 LX 4-banger 78k miles
Old December 18th, 2007, 06:31 PM   #2
02 Mustang GT
Cant wait to find out
Black Five 0h is on a distinguished road
this happened to me, but it was right after i got done doing my heater core, i checked everywhere for a bad ground or a short and that was the problem my glovebox light was grounding out on the metal frame my dash attaches to. if thats not your problem im not too sure what could be the probem, check all of your connections your blinkers are behing your steering wheel on the column the top plug, if your hazrd lights are disconnected that will cause your blinkers not to work.check the plugs in the back of your heater contols, maybe dead.
02 Mustang GT
"We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals."
Old December 18th, 2007, 07:09 PM   #3
92hatchback's Avatar
92hatchback is on a distinguished road
same exact thing happened to me and i still haven't figured mine out. one night the turn signals are working and the defrost the next mourning neither was working. Ive been driving for like 2 weeks with no blinkers.. tell me if you find your problem
Old December 18th, 2007, 10:07 PM   #4
02 Mustang GT
my problem is not exactly the same, but i do have a charging problem today again, if you guys have done anything new to your cars, like messing with anything electrical then go back and redo it.
02 Mustang GT
Old December 19th, 2007, 01:55 PM   #5
kuskye25's Avatar
all anyone has told me so far locally is it has to be a problem in my fusible links as i dont have a engine compartment fuse box..... so im buying a tester today to find which one is bad and replace it, i have 2x18ga and 4x16ga fusible links that i can find so far.. ill post my results sometime today.
Old December 21st, 2007, 03:02 PM   #6
kuskye25's Avatar
Ok after like 8 hours of diagnosis i figured it out, main thing that led me to my problem was using a test light on fuses while the ignition was in the on position. three different ones in the interior fuse box were completely dead "good fuses just no power to the fusebox". So i preceeded to open up the steering console and the main connector in it was slightly unplugged. Pushed that in till it clicked and all problems fixed, i have heater fan turn signals and rear defrost again along with everyhting else.
All is well with my stang finally, hope this helps someone else...
Old December 21st, 2007, 05:01 PM   #7
02 Mustang GT
now my fuel pump isnt getting power, the pump is not dead i checked it, now i will check my fusebox with the key on and see if that is something to do with it. i have no idea where to even start im about to hire someone
02 Mustang GT
Old December 21st, 2007, 07:24 PM   #8
kuskye25's Avatar
im pulling for you blackfiveoh, hopefully a fuse test light on all the interior fuses will reveil some more info on your issue... I hate having to hire shit done hahah
Old February 7th, 2010, 07:12 AM   #9
1988 mustang hatchback
88sbcmustang has a little shameless behaviour in the past
if you havent already figured it out its a plug on the steering column if you push up on it it will work you need to replace it
Old February 7th, 2010, 10:32 AM   #10
87StangGT's Avatar
1987 Mustang GT
87StangGT is on a distinguished road
hey 88sbcmustang you just re-opened a thread from 3 years ago.
Threads Similar to: 1988 Mustang Electrical Issue
1988 Ford Mustang GT Convertible Mustang Problems ridebmxfbm 5.0 Mustangs 18 May 14th, 2007 02:35 PM
Having an electrical problem with 99 mustang PRODUCTZER01 Audio/Video 3 April 8th, 2007 05:48 PM
Electrical Issue wilburgtwoot Audio/Video 3 February 19th, 2007 11:52 AM
Electrical Issue Find It And I'll Give You A Dollar C MY 4D 5.0 Mustangs 18 September 4th, 2006 06:30 PM
