Posi...?
Old December 18th, 2007, 08:37 PM   #1
Stangman50's Avatar
Stangman50 is on a distinguished road
Posi...?
i wanna rebuild my cars stock posi! i dont know where to start, ive already got new disc's that go inside...!
Old December 18th, 2007, 08:42 PM   #2
1987 ford mustang gt
well see when shes done
eeeehhhhhhhh!!!!!
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old December 18th, 2007, 08:49 PM   #3
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
Not to sure on that one
Old December 18th, 2007, 08:51 PM   #4
02 Mustang GT
Cant wait to find out
Black Five 0h is on a distinguished road
50 resto has a kit, you need new clutch pack its kind of hard to find on the site either that or it was just me, that includes everything to do the job. also americanmuscle.com has a gear instalationn kit you should probably get that it comes with your bearings just to do it while youre in there
02 Mustang GT
"We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals."
Old December 18th, 2007, 09:08 PM   #5
Speedstang302's Avatar
13.64@101mph
just buy some richmond gears..and an tlock rebuild kit ...and have an reputable shop do it
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old December 18th, 2007, 09:37 PM   #6
ryans88gt's Avatar
The directions come with the ford kit. It's not hard.
Jack the car up and support it with jack stands on the axle. You start by removing the diff cover, drain the fluid. Take the small bolt off the pin and slide the pin that goes through the middle of the diff out. Push the wheels/axles in towards the center of the car. This will expose the C-clips. Take the C-clips off. Drive the S-spring out with the wooden side of a hammer. Now you slide one axle back in and put the car in gear. Turn the axle slowly and the planetary gears will spin out. You can now take the diff gears out with the steels, clutches, and shims. Measure the clutch pack with a micrometer. Soak your new clutch packs in gear oil for an hour. Then stack the clutches with alternating steels (this way you can fit 4 clutches in there instead of the stock packing that goes clutch-steel-steel-clutch) Reuse the one clutch that is at the back of the diff and turn it over (the rebuilds only come with 3 clutches). Measure the new clutch pack and put use a shim that will bring the total width up to the same width as the clutch pack when you disassembled it. SHould be around 0.030". Reassembly is the opposite of dissasembly. Getting the s-spring back in is the hardest part. Use two worm clamps to squeeze the spring down and slide it in, then take the worm clamps off and pull them out with a pair of vise grips. Refill with 80w-90. Oh yeah, don't forget the friction modifier.
Old December 19th, 2007, 01:30 PM   #7
Stangman50's Avatar
thanks guys ,, all these ideas help..!
Threads Similar to: Posi...?
Trac Lok Posi vs Eaton Posi? cosworthpower Modular Mustangs 4 April 24th, 2008 03:01 AM
Posi!!! StangFreak4 General Tech 2 August 1st, 2007 10:01 AM
8.8 posi nightrunner 5.0 Mustangs 10 April 11th, 2007 12:37 PM
how much is posi? Mystry 96-98 2 August 15th, 2006 06:51 PM
