What Fuel Presure For 24lb Injectors
what fuel presure should i run.. i have a 86 block converted to MAF and e303 cam / heads / intake ,etc I put 24 lb injectors. it ran a little stronger on the bottom end with my 19 lb injectors in, but fuel presure was set at 42 ish.
what should i set my 24's too ? i also have a 65 MM throttle body on but i have a 70 MM, thinking about putting it on
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion |
i wouldnt go any higher than 44-45
38 lbs right now
well I am still trying to dial in this motor. it runs strong but feels like it has a real slight miss while driving but not under hard acceleration.
I had the fuel set at 42 lbs, but backed it off to 38 seem to pull a little stronger. I am still also playing with the timing now when i had my 19 lb injectors in i set at 42-44 and it ran great, but these 24 flow to much fuel at that pressure.
38 psi while the vacuum line's disconnected.. if it does have any.
oh, ok . i set it with the vacuum line on and running. set it with no vacuum on ?
thanks
ok adjusted it was like 42 ish when i pulled off vac line..adjusted to 38 and it helped alot !
Thanks to Mr. Jim Roal, you don't know what you're missing if you haven't read his tech articles & Q&As:
http://jroal.home.mchsi.com/ |
By the way, increasing the pressue of the rails affects the injectors negatively.. as you keep increaing that, your electronic injectors will need more force to lift up it's internal plunger in order to spray the fuel mist.. that would lead to premature failures.
ok thanks 38 lb's set correct now. and runs a lot better
question timing/fuel pressure
ok, i set fuel to 38 lbs like my last post say's...its running better but when i dont have my foot in it and am just trying to cruise.. it feels like it has a small mis...so i have too issue's i checked fuel pressure again. here is whats going on..when i have the vac line on and the car is at idle (800-950 rpm's) it show 30-31lbs wheni rev it it spikes to 35 then drops to 25 and floats betteen 24-26 lbs. does that sound right ? vac line off it set at 38 lbs at idle. , i also have the vac line hooked right behind intake ..is it getting to much vac ? should i move vac line to vac header ?>
i am also playing with the timing. another issue there.. when i pull the plug (chip) to set the timing nothing happens. i thought the idle would change...its like the dam thing is not hooked up or something? timimg i know should be 10-14 with chip pulled but i have it like 30-40 because the chip is not doing anything, car run pretty good, just that little bit of mis when i am not puring the gas too it. is there some were i can jumpper that wire the chip goes to to make it work ? thanks
Nope.. That doesn't sound right, Chad.. why's your idle at 950 rpm to begin with? that, plus saying that the engine misses at idle speed or low speeds.. and your fuel pressure regulator symptom.. they lead to one conclusion to me: vacuum leak!!
try tightening all those clamp screw but not too tight or will break that plastic tree.. check the hoses for cracks & listen for hissing noise.. some books say use soapy water but I cant see how! its a vacuum line not a boost line... if you have a cracked intake manifold gasket, carefully spray a can of carb cleaner or CRC around the manifold & see if the engine revs up.. About timing & your spark-out or "spout" connector.. you just CANT have 30-40* of ignition advance at idle - not talking about total timing here.. how did you check for that?! |
with a timing light. it goes to 30 deg. and its a ways above that !. i can turn it back to 10-12 but it does not want to run. and the spout seems to have no effect on it.
Anybody?
Are you shuting the engine off...pulling the chip...then starting engine to set the timing??? you can not pull the chip while it is running and get an accurate reading...
Other thing it may be ( seen this often) is if your balancer has spun.. I went through 3 myself before I bought a non rubber insert style.
www.freeautomechanic.com |
#15 | |
no i am not pulling chip before i set timing...but in the past when you pull the chip(timing plug) the engine RPM changes (alot) right now no change like it is not hooked up ?
i checked the yellow wire going to the chip and not voltage there while car is running. i would think that it should be hot.
ok its working now ? must have been a loose wire on the EEC
here is another question n a fresh rebuilt motor(302 now 306), does it have more compression before or after break in ?I have been playing with my timing and at one point had it way over 14 deg with no pinging, ran great just did not want to cruise very well, so how did I get away with that unless my compression is low do to engine only has like 30 miles on it ?also when i rev ny motor my fuel pressure drops from 31 to 25 ish with vac line on ? does that sound like a cloged pump screen ? and do these car have a fuel filter on them other than that ?
your compression is optimum soon after the break-in cuz all those microscopic peaks & valleys are ground and the piston rings are well seated
you have to inspect your vacuum lines.. troubleshoot with EVTM there are only 2 replaceable fuel filters: one screen mesh at the intank fuel pump suction, and one on the discharge line (the Bosch one which you usually change everything 50,000 miles) - of course, each injector has a built-in mini filter of its own. |
were is the one on the return line ?
also on the 2 line were they come up into the engine compartment one is a little small around and the other that looks bigger is in a sleave of some type which on it the return ? because the small one got kinked over when i pulled the motor but it looks ok now
Yes Zak I ment the balancer came apart at the rubber part...Mostly due to NOS... When this happened I could set the timing at 36 Degrees at idle , cause it was reading wrong due to its new location. There is a fuel filter below the trunk infront of the gas tank. If your fuel pressure is decreasing when you rev it ...I would look at vaccum lines as suggested by Zak
Threads Similar to: What Fuel Presure For 24lb Injectors
| 24lb injectors + air mass meter? | 1990CA50 | 5.0 Mustangs | 4 | January 4th, 2007 09:42 PM |
| Will Not Run On 24LB Injectors | Euroeater95 | 94-95 | 5 | November 4th, 2006 10:24 PM |
