Setting Distributor and Timing on a 93 5.0 that is carbed.
I have a 93 5.0 engine I have converted to carb and Mallory distributor with mechanical advance.
Accidentally rolled over engine with out distributor in and now at a loss to figure out how to position this so it will fire right. It doesn't seem to have the standard timing marks on the balancer, just one large groove cut into it, and a metal bracket on the block marked TIME. If I get these lined up is this Cylinder 1's TDC on EFI engines? How do you check the advance if there aren't any degrees marked? Thanks for any help. |
easy, find # 1 cyl should be PS front, take the plug out. put a small long wire in there (or something) turn car over by hand(socket on crank shaft,or someehere ) and turn it over slow intill the wire is pushed out as high as it want to go. this will be top dead center. now find the plug wire trace it back to cap when you set in the Dist back into motor the rotor should be pointed at this plug wire on the cap.
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion |
#3 | |
ok, well would it still run 180 out, and if so what side effects, because i forgot to check mine to see if it was on the compression stroke before doing it also. mine runs but i am still trying to dial it in feels a little week
usually they backfire really b ad through the intake if they are installed 180 out.
Thanks for the advice, but does the timing mark (groove) on the balancer also mean TDC for this cylinder also?
Put your finger over the spark plug hole and cheak for compression stroke. Or pull valve cover off and watch the intake and exhuast valves to cheak for compression stroke. #1 cylinder is front passenger side.
the motor will only blow out on the compression stroke, because during exhuast, the port will be opened, so hold ur finger over the hole until u feel it blow, the stick something that wont break off in ur cylinder or damage anything and get the piston to TDC as high as it will go... and wherever the rotor inside your cap is pointing, that it where your number 1 wire should be and check your firing order and install wires accordingly
and yes, the mark on the balancer should be topside towards the passenger side a little when the piston is at TDC
Thanks guys, I knew I would get great advice here!!
Clean the balancer up. There are timing marks on it.
Just cleaned the balancer and discovered the markings, just covered by surface rust. The big groove is 180 degrees away from these, totally sent me on a wild goose chase.
Thanks for all your help, hopefully will have it fired up in a few weeks. |
Threads Similar to: Setting Distributor and Timing on a 93 5.0 that is carbed.
| Carbed Distributor | gtstang87 | 5.0 Mustangs | 10 | September 13th, 2007 04:31 PM |
| 5.0 EFI to 5.8 (carbed to EFI) | SVT Town Car | All Other Vehicles | 12 | July 8th, 2007 09:41 PM |
| im going carbed | BCR93stang | 5.0 Mustangs | 50 | July 6th, 2007 06:45 PM |
| carbed | skid6 | 5.0 Mustangs | 1 | June 16th, 2007 06:05 PM |
| Setting the timing? | MySallyMI | 99-04 | 10 | August 11th, 2006 12:10 PM |
