No Heat
just wanting to see what everyone else thinks im getting no heat what so ever outta my heater ive checked the hoses running up to the firewall and they are plenty hot but my heater core isn't leaking either though so if someone could throw out some ideas be great to hear it
there can only be one....
1990 GT
is the car over heating if you let it run for a bit? if so your thermostat could be bad
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
1993 Mustang LX Vert
I have the same problem, and it seems that when you change from say defrost to floor or elswhere it dosen't change the route.
This happened in another car that wasn't a Mustang but may apply here as well. Underneath the dash on the passenger side was a white clip that plugged a bunch of hoses together. Somehow that came apart just enough to leak, and the system would do exactly what you're saying. So I'd check around under there and make sure everything's snug and see if that helps.
That is a vaccum problem or a bad vent door acctuator
1986 Mustang GT t-top time piece! |
no it dont overheat one bit
how would i go about seeing if it was a vacuum leak cause its blowing out air fine just no heat
#8 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
My car does the same thing, I think its a fail safe thermostate that has stuck open so the coolent never slows down enough to heat up. my car doesnt overheat but it takes a 15 mile drive to feel even a little warm
hmm yeah ill give that a shot first sence it is the cheapest
There are a few possibilities. It could be the thermostat and it doesn't have to over heat. If the thermostat is stuck open you will have a low heat issue but on the factory gauge the car will appear to be running at the normal operating temperature since they read low on the factory gauge anyway. Another possibility is the heater core being plugged or the heater control valve being bad. With both hoses going to the heater core feeling warm I'm going to rule out the control valve. The heater core however could be bad or have blockage. Just because both hoses are warm doesn't necessarily mean there is coolant circulating thru the heater core.
not switching between floor, vent, or defrost thats the vac problem. not the air temp problem
1988 lx
9.68@142
could be the switch not switching from cool air to heat..
That would be the heater control valve
Threads Similar to: No Heat
| keep intake heat down? | blakeasaurusrex | Modular Mustangs | 4 | September 7th, 2007 12:24 AM |
| no heat | hmotes | 5.0 Mustangs | 8 | January 15th, 2007 04:24 PM |
| extreme heat | lemon | 99-04 | 9 | December 29th, 2006 08:56 PM |
| Heat / Air | terribleonexx88 | 5.0 Mustangs | 3 | October 19th, 2006 12:09 AM |
| Please help with the heat | tdurbin | 5.0 Mustangs | 12 | May 19th, 2006 11:15 AM |
