Discussing Do I Have 3.73 Gearing? in the 5.0 Mustangs Forum. i have an 87 gt with 225/55r16 on the rear and a T-5 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
!987 Mustang Gt (Summer Car) - Ford Racing Headers, Flowmaster American Thunder Exhaust Without Cats, Flowmaster Hushpower 2 Mufflers, March Performace Ram Air Kit And Pullies, BBK Short Throw Shifter. 1997 Ford Taurus SHO (Winter Car) |
Maybe 3.55 gears?
89 LX 515 hp 497 ftlbs 88 GT 11.4 @ 118
1993 Mustang GT
Probably a stock 3.08.
Bart 93 Black on Black GT Kenne Bell S/C 3.73 Gears Tremec 3550 5 spd with Pro 5.0 Shifter BBK Catted X Pipe/2 Chamber Flowmasters |
#4 | |
If you have a .68 fifth gear, you have a 3.48 which is close to a 3.55. If you do not know your 5th gear ratio, use 4th gear (which is 1:1) and plug the numbers into this equation: axle ratio = RPM X Wheel_Circumference / trans_ratio X 1056 X mph Wheel_circumference for a 225/55/16 is 80 inches 120 km/hr = 74.5 mph trans_ratio in 4th gear is 1 Either way, speeds and tachs are no where near accurate and you will have to estimate. Do like the other recent thread states and turn your drive wheels and count the drift shaft turns, it will be right every time.
1991 GT - Original owner, all stock 1988 GT - The project car Last edited by nolife : December 19th, 2007 at 12:06 PM. |
1988 Ford Mustang GT
8.372@82.8 1/8mile w/1.825 60'
3.08
I never thought I would own a mustang!!! |
#6 | |
I miss calculated KM to MPH...somehow I got 67 mph Also you are correct about the tach and speedo being off. My stock tach was off by 400 rpms at 3000.
thanx for the help sorry i'm canadian my cars in km lol
It's relatively easy to find out another way. Mark the rear tire in a spot with chalk. Mark the driveshaft in a spot also. Start spinning the driveshaft. However many times you have to spin the driveshaft will give you your gear ratio. Unless you've owned the car from new, ya never know what gears are in the rear anymore.
#9 | |
Rotating The Earth 1320 Feet At A Time!! The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” |
SLOW
Mark the drive shaft with chalk...
Mark the bottom of the tire with chalk... Rotate the tire and count how many time the drive shaft turns per one full rotation of the tire... 3 1/4 rotations - 3.27 3 3/4 rotations - 3.73 4 1/10 rotations - 4.10 So on and so forth... |
1986 Mustang GT
Location: FOUND BWAL! hes now giving hand jobs to all paser bys
A little more than 3.08 I would think mine revs around 2500 and 70 MPH and thats like 120 kmh isnt it
2005 skittle
low 13's
120 kph is 74.57
30 19 50 31 60 37 80 50 100 62 120 75 1 mph = 1.609344
2005 - one fast ass black skittle TURBO HO
MILITARY CREW BM3 |
1986 Mustang GT
Thanks WT your a life saver
2005 skittle
low 13's
MILITARY CREW BM3 |
1990 Mustang GT
9.39@76.09----1/8th mile
i have 2.76 gears and im doin around 83 mph at 2000 rpms according to the stock tach if that helps anything
My 91 has 2.73's. 1K rpm for every 40 mph. Nice for the long highway trips cruising at 2K going 80. Sucks for everything else though.
1991 GT - Original owner, all stock 1988 GT - The project car |
1990 Mustang GT
+1......everyone i tlk to is like i bet your car getts crappy gas mileage and then im just like actually i get about 27-28 on the highway and17-18 in town and they usually dont even believe me
ok guys this is going to help much lol.. 3.73 gears, 4th gear at 2k rpm should be about 40 mph. test it out.
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
Threads Similar to: Do I Have 3.73 Gearing?
| Gearing for a 94 5.0 | mxman292 | 5.0 Mustangs | 2 | July 29th, 2007 04:51 PM |
| gearing | Mustang RacR94 | V6 Mustangs | 9 | June 29th, 2007 12:13 AM |
| gearing | EBuck | 99-04 | 10 | February 17th, 2007 07:50 AM |
| Help (V6 Gearing) | uniqueblackstang12005 | V6 Mustangs | 7 | October 23rd, 2006 02:03 PM |
| gearing | 88notch | 5.0 Mustangs | 3 | April 26th, 2006 07:46 PM |
