Choosing A Cam For My Combo?
Old December 19th, 2007, 06:38 PM   #1
Darrellx14's Avatar
Darrellx14 is on a distinguished road
All right. Stock bottom end. And i've purchased an Edelbrock performer rpm intake, 70mm throttle body, 70mm cobra maf meter, and working on a set of World Windsor JR 180 heads w/ Alum 1.6x3/8 rockers and hardend factory length pushrods. I'm trying to decide a camshaft for this new combo. I've narrowed it down to 3, unless i can get some new advice. Cams are Steeda #18 cam(220/226 & .480/.480), Comp XE270HR (218/224 & .512/.512) and the TFS stage 1 (221/225 .499/.510). Which cam would best suit my combo? and depending on the cam, what kind of power do you think it will put down?
'87 Mustang 5.0 T5 Coupe
New motor I/P: stock shortblock Edelbrock heads Typhoon Intake 70mm TB 80mm MAF 24lbers 1.7 rr B303 cam. Shooting for 300rwhp?
Old December 19th, 2007, 07:04 PM   #2
The Razor's Edge
White Thunder's Avatar
ok the big question is are you going to be doing future mods.....like a stroker or anything along those lines....if you are the cam should be one of the last things you buy unless you know what you want from the start
founder of the FTN Club
Old December 19th, 2007, 08:53 PM   #3
Darrellx14's Avatar
well, I'm leaving the bottom end stock until it breathes no longer, then I'll look into some other options, but that will not be for awhile. I'm looking for a cam for my combo i'm putting together at the moment.
Old December 19th, 2007, 11:27 PM   #4
Darrellx14's Avatar
I guess I'm just gonna go trickflow! It was my first decision.
Old December 19th, 2007, 11:52 PM   #5
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
that or a custom comp cam.....its almost always the best option because it fits wat you have
Old December 20th, 2007, 12:27 AM   #6
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Out of the ones listed i would say that comp 270HR or possibly something with a tad more lift and duration.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old December 20th, 2007, 12:40 AM   #7
baine21225's Avatar
+1
Old December 20th, 2007, 02:06 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
None of the above.
Old December 20th, 2007, 05:28 PM   #9
13.64@101mph
Originally Posted by Darrell View Post
None of the above.
+1
first off get a bigger MAF sensor...you might as well do the injectors now, along with that a bigger fuel pump and along with that a AFPR...
and i would look into getting either a custom grind comp cam, trick flow stage 2 or a crower camshaft...
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old December 24th, 2007, 12:37 AM   #10
Darrellx14's Avatar
well, I'm hardpressed for money, that's why I'm not getting a custom cam. I'd be looking for a good used cam. i thought the trickflow stage 2 would be too big for the factory shortblock
Threads Similar to: Choosing A Cam For My Combo?
choosing a cam efulton95 94-95 7 October 22nd, 2007 01:31 PM
Need help choosing perfect head air flow for the combo? 302 5.0 Mustangs 5 September 16th, 2007 09:05 PM
Need help choosing perfect head air flow for the combo? 302 5.0 Mustangs 0 September 12th, 2007 04:25 AM
help choosing cam 97TunedMustang V6 Mustangs 5 February 13th, 2007 12:48 AM
Help Choosing Oil AM1AW 2005 - 2010 9 November 7th, 2006 09:09 PM
