AC Delete and Smog Pump Delete
Hey Will taking this crap off give me the little boost I am looking for. My ac doesn't work right now so why not remove it. The smog pump well it's a smog pump screw that I will remove it. Qestion is who much better will my ar run??
It is all stock except for a CAI. |
It will not give you much if any power, but if you remove all the EGR and smog stuff along with all the AC stuff it will take over 100 lbs off the car and improve your 1/4 mile by a tenth or two.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
cool, I heard it helps the engine run smoother without the smog pump thanks
Yes, males for a much more efficient engine. Efficiency+weight reduction=
Actually a functioning EGR system improves efficiency and mpg, while reducing pollution. The only reason to get rid of it, is if you want to reduce weight.
#6 | |
95 opalfrost gt
+1 and If you do get rid of it,you should have the EGR function turned off in the pcm. That would be the correct way to do it.
Or get a EGR eliminator that mimics the signal of the EGR and remove the EGR valve.
#8 | |
95 opalfrost gt
Thats just a band aid to trick the pcm into not to throwing a CEL. You will still run the risk of being on the lean side.
could u tell me a lil more about this lil trick? cause i no longer have my smog pump and would like to know a lil more about the egr eliminator
there can only be one....
#10 | |
the EGR eliminator is used when the EGR is deleted. it plus into the EGR Valve Position (EVP) sensor's harness connector and indicates to the ECM that the EGR is closed always. this triggers a code 33 (EGR valve opening not detected). this is the only EGR code that does not cause the CEL to come on. when any EGR code is logged the ECM disables EGR strategy. EGR strategy increases timing advance in order to compensate for the cooling (retarding) effect of EGR gasses in your combustion chamber. the only chance of detonation when disabling EGR is if you block the EGR port but leave every EGR system component attached and functioning. any other method of disabling the EGR will cause a code which will in turn cause the ECM to disable the increased timing advance that would otherwise cause detonation. |
So, you can remove the smog pump without messing with the EGR?
yes. the smog pumps primary function is to add air to your catalytic convertors to facilitate the burning of the HydroCarbons that were not used during the combustion process
I need to look into that. There are a slew of hoses coming off of that system. Cannot follow them all. But it needs to go...
Thanks for the info tengram where can I find this egr elimitator or can I just use a cobra intake since it doesn't use an egr
#15 | |
Threads Similar to: AC Delete and Smog Pump Delete
| Smog Pump Delete? | 5-0stank | 5.0 Mustangs | 20 | July 14th, 2008 05:24 PM |
| SMog pump delete kit | javier351lx | 5.0 Mustangs | 9 | August 20th, 2007 03:24 PM |
| smog pump delete | bigwhiskey | 5.0 Mustangs | 4 | July 1st, 2007 12:02 AM |
| How To Delete Smog Pump On 95 GT | the95..5-0 | 5.0 Mustangs | 2 | September 13th, 2006 01:43 AM |
| Smog Pump Delete | mdvaldosta | 5.0 Mustangs | 2 | September 11th, 2006 12:13 PM |
