02 Mustang GT
Cant wait to find out
![]() iTrader: 1 reviews
Fuel Pump Wiring Problem
so i thought that the wiring was good to my fuel pump, but now when i check it while its out of the car it will turn on soo i have no idea... are there any fuses or anything besides the relay i should be checking, also is there anything else that doesnt deal with the fuel pump that could be giving me a problem?
02 Mustang GT "We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals." |
I have honestly search for a week to find my problem, switchng pumps and then changing relays. I found the problem to be a shitty corroded wire. It was the connection in the drivers side kick pannel. it is the connector that runs to the fuel relay under the seat. I think there is 3 wires in each end of the connector. when i touch it it literally fell out and was very very green. aperently this is a common problem i cut out the wire and just hard wired it and bingo no problem. Also my buddy had a prob with his wires to his relay being chewed under the seat from sliding the seat forward and aft. check those items.. the only other item would one of the inline fuses inthe engine bay the goes to the relay.
hope this helps cheers |
The Razor's Edge
where is tengram....he is great at this
02 Mustang GT
bad fuel pump relay connector, the power wire ripped out, thanks for all the help.
Threads Similar to: Fuel Pump Wiring Problem
| Fuel Pump Problem? | chaosstangman | 5.0 Mustangs | 3 | December 19th, 2007 12:39 PM |
| 42lb Injector & Fuel Pump Install Problem | hardhitter | 99-04 | 22 | November 22nd, 2007 10:17 PM |
| Fuel Pump Problem | RyanGT | 99-04 | 2 | November 11th, 2007 04:18 PM |
| 1990 Ford Ranger XLT fuel pump problem | ScyraxxX | All Other Vehicles | 22 | August 9th, 2007 03:15 PM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 04:31 PM |
