Discussing rare part!!!???!!!??? in the 5.0 Mustangs Forum. so i realized that there was a wire that came out where the fuel pump ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1990 Mustang Lx
??@ i wanna know
so i realized that there was a wire that came out where the fuel pump relay connects to. i believe it is called a "fuel pump relay connector pigtail" according to the factory. anyways i was just wondering if anyone knew where to find one, but here is the trick i need one that has the wires already attached to it...if anyone can help...please do!
You mean this?
Rockauto.com has them for under $10, I'm sure other places do as well.
1991 GT - Original owner, all stock 1988 GT - The project car |
1988 lx 5.7
11.6@109
JUNKYARD is your best bet or look on craigslidt for ppl parting out their mustang
Another note.. The Ford fuel pump relay is nothing special. If that is the part you are looking for, instead of sticking with the Ford style, you could replace the whole thing (relay and socket) with a standard Bosch style 30A automotive relay and socket. Everyone sells those things. You would need to figure out what color goes where though but if you know anything about relays, it is easy to figure out. Using the wires already in the car attached to the original connector as a guide, the two thicker ones would connect to pins 30 and 87, the two thinner wires connect to pins 85 and 86. If your Bosch relay has a pin 87A, cut off and insulate (tape) its wire off the pigtail connector as you do not need it. I've had no need to do this myself so if you go that route, let me know if it works
1991 GT - Original owner, all stock 1988 GT - The project car Last edited by nolife : December 23rd, 2007 at 11:05 PM. |
1990 Mustang Lx
??@ i wanna know
would this work??
1988 lx 5.7
11.6@109
the aftermarket relay?? yeah as long as you know how to use a relay.. it is real easy i am sure u can find out how to use it online. if u can read wireing diagrams then u can look at the picture on the relay.
i'm not sure what the problem is. i linked you to the relay connector with the wiring pigtail yesterday. are you not wanting to splice wires or what? if you're looking for the entire harness (its a pretty sizable harness that goes to multiple items) then your best bet is the junkyard or you could contact fordfuelinjection.com to see if they have the entire harness.
1990 Mustang Lx
??@ i wanna know
i didnt see a link of the connecter i need with the wires, and i do want to splice the wires, sorry i must have just not seen it.
Are we talking about the same thing when stating "connector with wires"? Most replacement connectors come with about 6-12 inches of wiring attached. You cut your old connector off and splice the new one into the old wiring. Is that what you do not want to splice?
If you personally do not want to splice that in, find someone competent that can. It will save you a lot of time, hassle, and money. Replacing an entire wiring harness because of not wanting to splice a new connector on is your choice but an insane one! I personally always use solder and heat shrink because I am anal about wiring but you can use crimp style butt connectors if you had too.
#10 | |
I know this only covers up to 88, but fuel pump relay wiring should be good as a guide.
</title></head>"); newWindow.document.writeln("<body><div align='center'><img " + getWidth("yes") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>"); newWindow.document.writeln("<div align='center'><table><tr><td><FORM |
Threads Similar to: rare part!!!???!!!???
| Need Help Finding RARE part please???? | lwhitetrash88l | V6 Mustangs | 9 | October 30th, 2007 04:49 PM |
| Rice, Funny, Weird, Rare, Odd, car pictures.... | 04GTAMPA | The Clubhouse | 40 | October 7th, 2007 08:49 PM |
| Clean your paint. (A rare serious Zip thread) | TheUNZippee! | The Clubhouse | 24 | August 4th, 2007 01:20 PM |
| this is so very rare | mustang1072 | Pictures | 11 | April 19th, 2007 07:01 PM |
| New Industrial Pics of Rare 95 | Bearcatice11 | Multimedia | 4 | August 7th, 2006 08:46 PM |
