Discussing Horsepower? in the 5.0 Mustangs Forum. dude go to a 347 if ur going to stroke it.. but if u stay ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
dude go to a 347 if ur going to stroke it.. but if u stay as a 302, or 306 which is a bored 302, the mods u listed above will net you 300horse.. heck i did over 300rwhp on a stock 91 5.0L motor with a super charger at 6psi and full exhaust! so i am positive heads, cam and intake and bolt ons will do that!!
#22 | |
Secret In The Works
And you dont "stroke" a 302 to a 306 (superman im not accusing you of saying this) Getting to 300rwhp isnt going to happen without heads, so make that the most important component on your list. You can make 300rwhp with a stock cam, so just leave the stock one alone. Just about ANY of the 5.0 intakes will support 300rwhp, whether it be N/A, Nitrous, Blown.. Turbo.. whatever, so its up to you what you want in that department. Your in the right direction with a bigger MAF, injectors, TB, headers and exhaust.
Definition of Fast? ![]() I'd say thats good enough. ![]() NMRA Outlaw 10.5 Season Opener 2008 Photo courtesy of - Yours Truly |
#23 |
#24 |
93 GT Hatch
12.68@112.57
k didnt know there was no hp/tq dif in a 306, but if thats the case get the rotating assembly for a 347. youll make 300whp no problem. but if the block was already a 306 or something then leave it get a nice h/c/i going and youll be fine even without the spray.
http://www.geocities.com/vz_one/superman5.jpg |
#25 |
Asshole™
1990 Mustang LX
9.36@143 mph
300hp at the wheels you can do with out even trying. A set of heads, intake and off the shelf cam will get you there with ease. No need for nitrous or strokers to get to that power level.
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#26 |
Secret In The Works
You dont even need an aftermarket cam. 300rwhp is easy as pie.
#27 |
#28 |
1993 Mustang LX
N/A
so If i just buy AFR 185cc heads, a cobra intake, 24 lbs injectors and full exhaust. Leave the stock cam, Bigger tb and maf. I knew someone you had more than that and only got 290 whp. Oh, well the my stock fuel pump work with the 24lbs injectors.
Fastfordsoftexascc.com |
#29 | |
Asshole™
1990 Mustang LX
9.36@143 mph
I'd put a 255lph pump in because it is cheap insurance.
#30 |
93 GT Hatch
12.68@112.57
i dunno about the 185 heads, you would need to notch your pistons for those to fit, i have 165s and they make great power. usually guys get 185s if they were to stroke it or supercharge or maybe even a turbo.
#31 |
1993 Mustang LX
N/A
turbo is later but not forgoten
#32 |
95 Mustang GT
?? waiting on the stroker
#33 |
1987 ford mustang gt
well see when shes done
I have said this way too many timees the stock vavle reliefs are not big enough for A 2.02 1.60 VALVE THEREFORE YOU WILL HAVE TO NOTCH YOUR PISTONS IF YOU DECIDE TO GO WITH A AFR 185 HEAD iF it was me i would either do a trick flow tw head or an afr 165 and a trick flow street heat intake.And i would not leave the stock pump in its rated to like what 80lph
#34 |
93 GT Hatch
12.68@112.57
then if your set on 185s make sure you get your pistons notched, for your future turbo.
#35 |
see if i was him i would just look into trick flow heads
#36 |
93 GT Hatch
12.68@112.57
im iffy on trick flow heads, i know they make the power and all but a buddy of mine at the shop had a pair and sprayed twice with just a wet 100 shot and cracked one of the heads, after i saw that i dont recommend them to anyone, i have my afrs and i love em.
#37 |
I know many people that use them and love them,they are not a bad company and make greeat products,where did the head crack by the way?
#38 |
1993 Mustang LX
N/A
money is some what stoping me from buyng tf heads
#39 |
1988 lx 5.7
11.6@109
+1
#40 |
they are no more expensive than any other head out there
Threads Similar to: Horsepower?
| Horsepower? | V6RedMustang | V6 Mustangs | 11 | August 9th, 2007 08:38 PM |
| Horsepower | garydahl | Poweradders | 1 | August 8th, 2007 09:02 PM |
| how much horsepower | kenevil331 | 5.0 Mustangs | 4 | August 2nd, 2007 12:38 PM |
| MORE HORSEPOWER | RALVAREZ26 | V6 Mustangs | 24 | July 29th, 2007 03:56 AM |
| Horsepower | blackthund3r | 5.0 Mustangs | 17 | July 26th, 2007 03:15 AM |
