347 Cooling Issue
Old December 24th, 2007, 02:08 PM   #1
bgddy50's Avatar
1991 LX Mustang
bgddy50 is on a distinguished road
347 Cooling Issue
Im running a 347stroker, with stock fan setup with stroud and an aluminum 4 row rad. Drive thru's are the issue or at least long stoplights. Does a 347 realy run that hot that a stock set up cant keep it cool? I may have introduced the problem by raising the motor about 1/2 inch at the mounts which changed the angle of the fan. I had clearance problems with the canton oil pan and Hydraulic lines on top of the rack and pinion. anythoughts are welcome.
CHP 347, AFR 185's, T-56, Maximum motor sport complete suspension, 3. 55 gears
Old December 24th, 2007, 02:10 PM   #2
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
First thing i would check is the thermostat. Could be stuck shut. Always the first to check with overheating problems.
Old December 24th, 2007, 02:13 PM   #3
The Razor's Edge
White Thunder's Avatar
can i have your car?.....
id say upgrading your cooling system should fix your problem...i take it you got the short block....did it come with a water pump or did you use a used one.....is a electric?
someone else should chime in that has a lil more experience
founder of the FTN Club
Old December 24th, 2007, 02:14 PM   #4
The Razor's Edge
+1
Old December 24th, 2007, 02:19 PM   #5
bgddy50's Avatar
1991 LX Mustang
thormostat checks out its brand new, high flow mechanical water pump installed myself. The motor is a long block from CHP.
Old December 24th, 2007, 02:23 PM   #6
woody1 is on a distinguished road
check to make sure the passenger side head gasket is on right, common mistake alot of people make
Old December 24th, 2007, 02:31 PM   #7
TurboLX's Avatar
1988 Mustang LX Turbo
do double fans and a fan switch
Old December 24th, 2007, 02:32 PM   #8
Goblin's Avatar
88mm
Just because its brand new, doesnt mean its working right. Just an idea.
Old December 24th, 2007, 02:39 PM   #9
bgddy50's Avatar
1991 LX Mustang
I tested it via the pan with water on the stove and a themostat. it popped at 195
Old December 24th, 2007, 03:55 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Driving down the road the car runs at normal temperature but idling or slow speeds it runs hot? If that is the case, your fan is not pulling enough air.
Old December 24th, 2007, 04:23 PM   #11
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
is it faceing the right way just thought i would ask not saying i have done it or anything...
Old December 24th, 2007, 04:30 PM   #12
Goblin's Avatar
88mm
That was my next question.
This mistake, i HAVE made.
Old December 24th, 2007, 08:19 PM   #13
airforcesvt1 is on a distinguished road
thermosstat would be my first choice!! id replace it anyways with another one.. there cheap enough and easy to swap out anyways!
second when its running, and you pull off the radiator cap, does it bubble up like there is air in the line?? if so its prob a headgasket!! like was said earlier ive seen this problem quite a few times!
and i bet ud be good with the fan and shroud, however i prefer dual electric fans and shroud!! there nice!! and you free up room!
Old December 24th, 2007, 08:24 PM   #14
ps i run a 347 aswell and ive never had my car go over 200 before! in the hot summer texas heat (where my wifes family is from) and i was supporting over 500horse at the wheels!!
Old December 24th, 2007, 11:46 PM   #15
nolife's Avatar
91GT, 88GT, 02GT
Since this thread has a thermostat question in it already...
Does anyone have a suggestion for a specific brand of thermostat? I have a 185 "hi flow" in my other Mustang but bought it so long ago I do not remember what brand or where I got it. Local Autozone only had "regular flow" 185 and 192/195. Another note, any opinions on 185 or 195 in a car running 10# boost?
Old December 25th, 2007, 12:06 AM   #16
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
he wasnt saying that the head gasket was bad.................
he was saying maybe he put it on backwards so one of the water jackets were block by the head gasket, via doesnt cool right....
Old December 25th, 2007, 04:19 AM   #17
No specific brand that i run, i just walk into the parts store and ask for a 180* t-stat. They have always worked for me.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old December 25th, 2007, 12:19 PM   #18
e3sean's Avatar
1988 lx
9.68@142
is anyone running stock cooling system with a 347 out there?? i dont think i could get away with it here.
Old December 25th, 2007, 12:35 PM   #19
Stangzilla's Avatar
Stangzilla is on a distinguished road
Well he said he bought a long block so the heads came installed..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old December 25th, 2007, 12:37 PM   #20
Stangzilla's Avatar
Moroso has a hi flow stat.. I have a 180 high-flow Moroso in mine..
Threads Similar to: 347 Cooling Issue
Cooling bargin WAR-PARTY General Tech 3 August 8th, 2007 11:10 AM
Cooling Question JBIGBOOTSY 5.0 Mustangs 2 May 20th, 2007 01:22 AM
Cooling Fan Stangzilla 5.0 Mustangs 23 March 25th, 2007 11:15 AM
cooling zhunter V6 Mustangs 2 January 25th, 2006 07:18 PM
