Discussing 87 dizzy replacement to older style in the 5.0 Mustangs Forum. what is different between the newer efi engines and the pre 85ish that makes the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1966 LUBR Bronco 1979 2.3t Cobra 1994 V6 Vert & a 351 ON A STAND 1997 Black Cobra 1994 Jeep XJ 4.5" lift 33"MTR http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
1990 GT
Pull the oil pump driveshaft, you will see a lock ring, you need to push this ring up further to allow the pump drive shaft to drop about another .5 inch into the pump. Alot of unsuspecting individuals seem to forget about this, and end up bottoming out there dizzy lock downs with the dizzy not seated. And low and behold, it gets twisted up, and screwed beyond all recognition. Was the oil pump drive shaft ever replaced?
Hope this helps some. Unless you already tried this? |
no i didnt try that i didnt even think of it and the pump was replaced by the previous owner so i hope he did that i got a deal on the car and am not real sure about what was really done yet.
you can do 2 things here and get it running pretty quick
buy a 1985 distributor(get one with a steel gear not cast iron) and a duraspark ignition box. or you can get the HEI 1 wire dist like you said. I have a 79 coupe and i just put a 5.0 in it and thats what i did. I found a billet HEI 1 wire dist on ebay for like $70 shipped, and it works good.
http://www.moddedmustangs.com/forums/vehicle-classifieds/86839-wtt-90-lx-hatch-red-black-north-alabama.html#post1394801 |
1990 GT
Hey, give it a shot. I remember I was going through hell trying to figure this out, and it worked when I moved the ring up.
#6 | |
#7 | |
1990 Mustang LX
9.36@143 mph
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#8 | |
I changed a 90 model 2.3 to 5.0 and used the 85 dizzy and msd box the 79 i just done i used the hei 1 wire. the 1 wire was inexpensive and easy install, but it is kinda tall and i think i gotta get an off set air cleaner base to run my 14 inch air cleaner. for the time being i am running the ugly ass edelbrock triangle shaped chicken wire air cleaner. beware of this air cleaner it will catch fire quick if you have your timing off or a vaccum leak and it backfires thru the carb!
Threads Similar to: 87 dizzy replacement to older style
| Older t5 in 94-95? | MeanGreen50 | 94-95 | 4 | December 7th, 2007 06:54 AM |
| A little bit older...... | XTCNAGT | The Clubhouse | 12 | August 24th, 2007 02:23 AM |
| older turbo'ed MR2 | FaStStAnG5-0 | Street | 5 | March 30th, 2007 07:04 AM |
| Witch MSD Dizzy | tag team | 5.0 Mustangs | 11 | October 24th, 2006 10:12 AM |
