Discussing Any Tips To Welding In A New Floorpan? in the 5.0 Mustangs Forum. I have no driver side floor, and the pass side is probably pretty bad, too. ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2003 Mustang GT
Not Ready Yet
Any Tips To Welding In A New Floorpan?I know where the good metal starts, but has anyone done this and documented it? Looking for tips, and if noone has took pics and documented it, I will be the guinea pig and get it done... Is there an aftermarket for floorpans or do I have to go get it from a junkyard? I looked and found nothing so far on the net.... Any help is very much appreciated in this, Ive never had to weld in a floorpan before now, was always lucky I guess....lol Ill post a pic tonight, Cant get to the car right now....
![]() REBEL PRIDE NEVER DIES!!!! Daniel Raymond Floyd 2003 GT COBRA -R Conversion underway ![]() |
12.37@110.89
Any Mustang parts supplier carries sheet metal. National Parts Depot, Dallas Mustang, etc. They have full floors or each side. I found a wealth of info on these installs just do some searching. I will check to see if I still have any of the links and post them later if you don't find any.
http://www.moddedmustangs.com/forums/image-apic687.jpg |
2003 Mustang GT
Not Ready Yet
THANKS!
I found the floor pans at DALLASMUSTANG, and they are alot cheaper than I thought they would be, welding them in is no problem, but if there are any tips out there to share, let me know. This is looking better at every turn. Thanks again
12.37@110.89
Here are a few links I had bookmarked:
http://www.mustang123.com/databases.asp Couple of good ones on classics - lots of pics http://bellsouthpwp.net/n/y/nylhtak/index.html http://eolson1111.tripod.com/mustang2/id21.html
Classic Moderator
When I think of rusty floor pan, I think of a Classic.
Classic Mustangs are the best! Get one. |
A good flanging tool, spot welds or rivets and seam sealer will do the trick. I'd also recommend making a "test panel" from a sheet of posterboard so you don't ruin the new panel by cutting it wrong
88 Mustang Coupe 2006 FFW Richmond True Street Runner-Up www.rickscarcare.net http://img146.imageshack.us/img146/2158/ricksadql2.jpg |
just a thought but have you talked to a body shop, i know alot use a glue to replace body panels. might be a huge time saver?
Classic Moderator
I can see parts falling off when he goes 120 hahhaha
2003 Mustang GT
Not Ready Yet
tgunner: Good idea, I will get some more info on that.
Horshoeing: lol I can see the same thing. When I sat in the seat if fell through and the carpet was the only thing holding me off the ground. it sat withno drivers window forGod knows how long before I got ahold of it. Twiast 2 Go: Do I want to put the new panel on the top or bottom of the old floor? I would say top, but I want to do this right so I am not afraid to ask questions. Thanks for the tips, yall, keep 'em coming
I'd do the top. It probably don't matter but it might be easier to do that way.
#11 | |
No More 5.0 |
2003 Mustang GT
Not Ready Yet
Roger that on the plasma cutter, but I am stuck with a reciprocating saw and a pnumatic cuttoff wheel
Top it is, I figured so, but always good to ask. I will check out CJPony parts, might get a deal there. Thanks yall, Keep em coming I promise pics tonight, I just got the dash and everything else out today, so I can survey the damage. Not too bad so far.
The sawzall will do the job just fine and no chance of starting a fire. Leave a half inch overlap and clean the metal of all paint, glue and rust. Then tack weld about every inch all the way around. After tacking go back and weld between tacks until you have a solid weld. Treat the bare metal with metal conditioner before painting. Go underneath the car after all of this and seal the seam from the bottom side with a non hardening seam sealer. Then paint and undercoat.
Be sure to cut back to good solid metal. Have a fire extinguisher handy while welding |
2003 Mustang GT
Not Ready Yet
OK, Here's the pics:
2003 Mustang GT
Not Ready Yet
some more pics:
2003 Mustang GT
Not Ready Yet
OK last pictures, lots of dirt, but no rust except on the floor pans...
2003 Mustang GT
Not Ready Yet
Not bad for 500 bucks....
12.37@110.89
looks like you got alot of work ahead of you but a good looking project car. You going to weld up all the little holes in the engine bay? Several local guys have done that on their coupes and they looked awesome when completed. Good luck and keep us posted on your progress.
What engine combo you going to put there?
2003 Mustang GT
Not Ready Yet
I hadnt thought about that, good idea!
That would look tons better when done. It took me about 8 hours so far. I go to Iraq in OCT for 4 months and it will set ide while Im gone, but when I get back Ill have some change to spend ![]() Hopefully I can get rid of the rust and maybe get the floor fixed before I go. Thanks!
2003 Mustang GT
Not Ready Yet
Thanks STANGINFECTION! Thats the stuff I was looking for!
Gracias amigo.
Threads Similar to: Any Tips To Welding In A New Floorpan?
| replacing The Floorpan | marks87gt | Convertibles | 3 | October 22nd, 2007 08:19 PM |
| This guy needs a little welding help. | 06VistaBlueGT | Videos | 11 | October 10th, 2007 01:21 PM |
| welding | terribleonexx88 | 5.0 Mustangs | 0 | September 9th, 2007 06:17 PM |
| Storm Drains Blocked (Puddle in backseat floorpan) | ToplessSteed | General Tech | 6 | July 12th, 2007 05:28 PM |
| Welding | Horseshoeing | The Clubhouse | 10 | May 21st, 2007 06:08 AM |
